question about oil ring
Old May 1, 2009 | 03:46 PM
dj-t's Avatar
Default question about oil ring
I have a b18a block (.25 over)and putting in new pr3 piston(.25 over) and rings (.50 over). Reason I went .50 over with the rings is that the .25 ring was at about .020in over the recommended gap so I went with the .50 over ring so I can just file it down to the proper gap size. But what about the oil ring, do I file the oil ring rail and oil ring or just the oil ring rail. If I was to file down the oil ring the grooves or waves wont line up. Will that be an issue if it doesn't line up?
Old May 1, 2009 | 04:20 PM
h224thgensedan's Avatar
Default Re: question about oil ring
What is your piston to wall gap like if your ring end gaps are that big? Are they OEM rings?
Old May 1, 2009 | 04:34 PM
phatrick2332's Avatar
Did you have the block bored over .25 or was it like that and your throwing new pistons and rings in. If you just had it bored and honed, you need to make a trip to your machinest and ask him where he left his glasses.
Old May 1, 2009 | 07:46 PM
dj-t's Avatar
I don't know the piston to wall didn't ask I guess since they have over 25+ years experience and through word of mouth heard they were pretty good I figured they knew what they are doing. I'll give them a call on Monday and bring it back to have them measure the bore. As for the rings it was oem .25 over with the pistons from honda but I returned the rings and got the hastings .50 over.
Another thing is that when I put the rings in push it with the piston 3/4 down and 2in down the cylinder there is a .002in difference. Is that how it is or something is really wrong here. Gonna double check this tomorrow.
Old May 2, 2009 | 10:04 AM
dj-t's Avatar
Sorry guys reread my post and as for the rings being 0.020 it is 0.002 over the recommended gap clearance. Thinking about it again .002 is not that big of a difference.
Should I have just installed the .25 over rings from honda since they are only over the recommended gap by .002?
Or was it a good choice to get the .50 over rings and filed it down to the recommended ring gap?
This is my first motor that I am building on my own so I want to get this motor built the right way so that the only thing I have to do to this motor in the future is maintenance work. Thank you for your help.
Old May 2, 2009 | 10:37 AM
92cxturbo's Avatar
what where the actual gaps for each cyclinder?
Old May 2, 2009 | 12:24 PM
dj-t's Avatar
Piston ring gap from the chilton book
Top ring is .008in - .014in I got .016in to .017in with the .25 over OEM rings on all four cylinder.
Second ring is .016in - .022in I got .024in to .025in with the .25 over OEM rings on all four cylinder.
Oil ring is .008in - .020in I got .023in to .025in with the .25 over OEM rings on all four cylinder.
When I put the .25 PR3 piston in the .25 bore over cylinder it is pretty tight barley any movement of the piston.
As for the .50 over hasting rings I plan file it down so I have it at .011in for the top ring, .019in for the second ring, and .013 for the oil ring.
Old May 2, 2009 | 08:35 PM
92cxturbo's Avatar
your gaps are still within service limit......
Top Ring: Service Limit: 0.60mm {0.024in)
Second Ring: Service Limit: 0.70mm {0.028in)
Old May 2, 2009 | 09:15 PM
stevenDAtegra's Avatar
I don't think the over sized rings will fit well enough. Sounds like trouble
Old May 2, 2009 | 09:35 PM
92cxturbo's Avatar
Originally Posted by stevenDAtegra
Sounds like trouble
thats what she said
Old May 3, 2009 | 07:39 AM
dj-t's Avatar
Originally Posted by 92cxturbo
You cant use a .50 over ring on a .25 over piston, and your gaps are still within service limit......
Where did you get that info from cause I am going base on the info in the chilton repair manual. Damn it could of been finish with this if I knew I did not go past the service limit.
Old May 3, 2009 | 08:46 AM
Taken from factory acura service manual
Top Ring
New .008-.014
Service limit .024
Second Ring
New .016 -.022
Service Limit .028
Oil Ring
New .008-.020
Service Limit .028
92cxturbo's Avatar
Helms.....
Old May 3, 2009 | 08:54 AM
DonF's Avatar
You will be fine, file the rings to fit like all real engine builders do.
Old May 3, 2009 | 09:49 AM
92cxturbo's Avatar
Are you sayin to use the .50mm over rings in the .25mm over bore? I always thought you couldn't do that?
Old May 3, 2009 | 10:18 AM
DonF's Avatar
Depends if you own a ring filer, or a set of small files and a feeler guage set. Some engine builders do, assemblers do not.
Old May 3, 2009 | 10:42 AM
92cxturbo's Avatar
well thats a given, I thought the ring would become out of round or something
Old May 3, 2009 | 11:01 AM
DonF's Avatar
Why?
Old May 3, 2009 | 11:06 AM
92cxturbo's Avatar
Idk, Ive always been lucky enough to use forged pistons with file-to-fit rings. Thanks to DonF I get to learn something new everyday!
Old May 4, 2009 | 08:35 AM
dj-t's Avatar
Since it took a month to get my .50 hasting rings during that time I purchase a ring filer from Summit Racing.
http://store.summitracing.com/partde...5&autoview=sku
But, I am still unsure for the oil ring does the wave's of the ring have to line up when the two ends meet cause won't they overlap each other.
Will this cause any issues in the future or it should be fine?
Thanks for everyone's help I really appreciate it.
Old May 4, 2009 | 04:03 PM
DonF's Avatar
You should be fine, do not overlap them.
rick_rabies
K Series
Sep 6, 2018 04:08 AM
EKB18BPR3
Jul 4, 2007 04:54 PM
jtracing919
Jan 25, 2006 05:06 PM
N20civicB18
Oct 25, 2004 06:55 AM
