Starter wont crank.....
Old May 1, 2009 | 02:19 PM
BrothaSit's Avatar
Default Starter wont crank.....
i check all the ground wires, check the battery and starter and its still not starting. the funny thing is that when i try to start it the cooling fan turns on anybody got any ideas what this could be?
Old May 1, 2009 | 02:22 PM
Adankid's Avatar
Default Re: Starter wont crank.....
have a couple of your friends rock your car back and forth, and then try to start it.
this is how we got my friends ef to start after we did an ls swap to it.
Old May 1, 2009 | 02:24 PM
forcefedferio's Avatar
tap on the starter with an extension and a hammer, you don't have to blast it or anything but try to start it after you tap it a few times. If that doesn't work tap it while someone else tries to start it, if it works then you've got yourself a bad starter
Old May 1, 2009 | 02:26 PM
EG6KILIN's Avatar
Im with forcefedferio x2
lPat
Nov 3, 2007 08:19 AM
jimboek
Apr 26, 2007 07:12 PM
porkchop14
Sep 28, 2004 09:10 AM
SiSoul
May 31, 2003 12:08 AM
