Vented Valve Cover questions
Old May 1, 2009 | 01:17 AM
Mr. Em1's Avatar
Default Vented Valve Cover questions
Hey guys i need to get my valve cover vented and have (4) -10 an bungs welded into one of my valve covers. how exactly do you go about doing this? i know you have to take out the baffles, but do you have to reinstall them? any help would be much appreciate! thanks
Old May 1, 2009 | 02:41 AM
Turbocivic94's Avatar
Default Re: Vented Valve Cover questions
When I did mine, I didnt take out the baffles. I just drilled the vc and welded -10an bungs.
Old May 1, 2009 | 04:34 AM
Brad Campbell's Avatar
Opposite experience for me... I removed the baffles and didn't reinstall. I have no oil/vapor control issues at all on my 4G63.
Old May 1, 2009 | 04:53 AM
rota92
Guest
Posts: n/a
For my D VC's I was putting in another smaller baffle in the back to just cover it up.
I have seen some B-series covers with just little tabs welded at an angle to block any oil from getting out.
Old May 1, 2009 | 08:28 AM
Mikey3000's Avatar
you should keep the baffles especially in the back of the vc.
Old May 1, 2009 | 09:51 AM
d16sandrail's Avatar
me too, I keep the baffling intact, just drill a hole in the surface of the vc, but not into the baffle.
Old May 1, 2009 | 11:08 AM
siblues's Avatar
I had mine done and they just drilled and welded the two bungs on.
Old May 1, 2009 | 06:40 PM
B R Fittings's Avatar
The easiest way to drill through the valve cover without going through the baffling on the inside is by using a stepped drill bit (aka uni-bit).
Old May 2, 2009 | 05:08 AM
Blown90hatcH's Avatar
And that usable baffling in the rear is where?
OP, just weld up some tabs on the inside to channel oil around. I make them longer now, but here is a picture I did from some years ago.
Old May 2, 2009 | 05:40 AM
Mikey3000's Avatar
I guess b series don't have rear baffles like the H does. If you put hoses on the rear I would suggest putting baffling over it so you don't lose so much oil when you accelerate.
Old May 2, 2009 | 03:38 PM
Mr. Em1's Avatar
nice thanks for the help guys, i guess its a bit easier than i thought!
toshiyuki
Apr 21, 2017 08:38 PM
sh!ft
Welding / Fabrication
Aug 12, 2010 01:06 PM
boosted91crx
Mar 31, 2009 11:19 AM
