D16z6 Sputtering/Missing
Old Apr 30, 2009 | 10:42 PM
92BLKINTEGRA's Avatar
Default D16z6 Sputtering/Missing
I have a 92 cx with a d16z6 swap in it, It started sputtering and missing little by little. now it's doing it almost all the time.. sometimes it runs fine and sometimes it sputters, loses power and sounds like a subaru, and judging by my MPG and the smell of the car.. it smells like gas.. running rich? Anyone else have this problem?.
Old Apr 30, 2009 | 11:06 PM
waaBAAH's Avatar
Default Re: D16z6 Sputtering/Missing
if you smell gas and is sputtering then it would make sense that your not igniting the fuel which means you dotn have spark on one cylinder or more.
check condition of your spark plugs. see which one is black since a dark color plug means that cylinder is running rich.
when it is sputtering pull each plug wire with the car running and which ever plug wire DOES NOT make the engine sound diffrently when pulled will be the cylinder your looking for.
could even be a leaking fuel system if your smelling the fuel. normally you wouldnt smell fuel from lack of spark.
but find out which cylinder is misfiring.
Old Apr 30, 2009 | 11:45 PM
Will do. Im just kinda lost with all this. I hate trouble shooting. but I will do what you say.
Old May 1, 2009 | 11:44 AM
I pulled the plugs and they had black around the bottom but the prong was white.. looked burnt? or is this normal
ratchetej1
Engine Management and Tuning
Aug 26, 2017 06:23 AM
Wisdom Teeth
Mar 25, 2013 10:26 AM
stephen_civic98
Feb 23, 2010 09:50 AM
spliffstarzzz
10
Nov 26, 2008 12:46 PM
JSpecwest
Jan 4, 2002 01:23 PM
