blown headgasket?
Old Apr 30, 2009 | 09:53 PM
TypeRMOBBiN209's Avatar
Default blown headgasket?
well i just got my type r head back from the machine shop for resurfacing and ready to mate to the type r block. well i let some idiot put the headgasket on and torque down the head bolts. i went on and finished the rest, but as soon as start up oil was gushing from the corner of the head and block by the thermostat.
Turns out he put the headgasket on the wrong way. So i remove the head cleaned everything up including the headgasket and reassembled it and fired it up but before the incident happened the motor was ran only for about 15 seconds.
So the engine runs great but theres always a little white smoke coming out of the exhaust. ive been driving since last night and today.
So could the headgasket be bad and need to be replaced and will i have to get my head resurfaced again?
Old Apr 30, 2009 | 09:59 PM
Adankid's Avatar
Default Re: blown headgasket?
switch out the HG immediately before anymore problems occur.
Old Apr 30, 2009 | 10:01 PM
forcefedferio's Avatar
x2 some people say you can reuse them which i completely disagree with, once that head is torqued down thats it. Make the idiot buy you a new one.
Old Apr 30, 2009 | 10:11 PM
alrite thanks...because i heard you can reuse to headgasket after its been torqued down just not after its been threw the heat cycle
Old May 1, 2009 | 04:21 AM
Dave-ROR's Avatar
Is it using coolant, or is the white smoke just steam? Worse case, you'll have to replace the gasket. I'm pretty sure we reused one on an 01 ITR before when someone was too drunk to notice they put it on backwards (we had leaking coolant and oil from it). IIRC we just flipped it and put it back together with no issues..
NorCal_ej1
Apr 17, 2016 06:50 PM
turbo1spunn
Engine Management and Tuning
Mar 31, 2016 10:53 PM
homoaranea
Sep 5, 2013 12:38 AM
methos713
46
Jan 14, 2008 12:54 PM
ITR_1211
Jan 5, 2004 09:04 PM
