95 si motore in a 96?
Old Apr 30, 2009 | 06:43 PM
MurtazaDSM's Avatar
Default 95 si motore in a 96?
will a 95 civic si vtec engine fit in my 96 civic hatch? it also comes with a obd1 wire harness please let me know asap
Old Apr 30, 2009 | 07:35 PM
MurtazaDSM's Avatar
Default Re: 95 si motore in a 96?
come on guys
Old Apr 30, 2009 | 07:37 PM
EG6KILIN's Avatar
Old Apr 30, 2009 | 07:53 PM
MurtazaDSM's Avatar
just a yes or a no
Old Apr 30, 2009 | 09:10 PM
egsleepercivic's Avatar
it will definitely fit, the wiring is going to give you a hassle, but its doable
gl
Old Apr 30, 2009 | 09:13 PM
forcefedferio's Avatar
yes, and the wiring actually isn't even THAT big of a deal, obd2a to obd1 conversion harness, re-wire IAC, 1 wire for knock, 2 for VTEC, and re-pin distributor.
medorihb's Avatar
anything will fit. if the money is right. hell you can put a ls1 in a hatch with the right amount of money. but yes it will fit. i would wait on a sohc vtec motor and put the money into a B or preferably a K.
Old Apr 30, 2009 | 09:48 PM
MurtazaDSM's Avatar
Well im getting it cheap and want a d series to build. So what else would I need other than the engine and tranny for it to fit
Old Apr 30, 2009 | 09:58 PM
Originally Posted by MurtazaDSM
just a yes or a no
ohhhh sooooo now you wanna hear us?! you will need (and i may be forgetting something)
The aforementioned obd2a to obd1 conversion harness to run the obd1 p28 ECU
96-00 Civic EX header and mid pipe (just keeping it simple, although you don't HAVE to use these if you want to do some customizing)
honestly i think that's it, in a D to D swap it's pretty much just the labor.
Old Apr 30, 2009 | 10:07 PM
Fatchance187's Avatar
most states it's illegal. I know here in MD the motor has to be from the same year as the car or newer.
Old Apr 30, 2009 | 11:02 PM
elmy eg6's Avatar
yeh it will fit, all u will need is a step down kit that will convert obd2 wiring to obd1 harness :] i would rather save up my money a lil and go with a b series. i hav a 93 si and i blew my single v motor n im loving my bseries 10 times more...no regrets.
Old May 1, 2009 | 06:58 PM
there is no knock sensor on the z6's , one less wire ...lol
also the alt plugs are different but, you can either swap the plugs or VRM
Old May 1, 2009 | 07:09 PM
ek4_b16a's Avatar
and it's illegal to put an older motor into your 96 civic. gotta be same year or newer.
turbodelsolb16a2
Jul 18, 2009 01:54 PM
ap1$2k
Apr 23, 2008 03:05 PM
ebonyrolla7
Jul 10, 2006 09:41 AM
jsnm
Jun 28, 2005 09:40 AM
TOMSBLUEHONDA23
Jun 5, 2005 09:09 AM
