Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
All Motor/Turbo Custom Pistons! 15:1 Whaaa?
Old Apr 30, 2009 | 02:11 PM
ExospeedAMcrx's Avatar
Default All Motor/Turbo Custom Pistons! 15:1 Whaaa?
Exospeed Race Engines
Custom All Motor and Turbo Pistons
What can a custom piston do for you?
  • If you’re looking for a bore size or specific compression that is not available off the shelf, a custom piston can get that for you.
  • The piston design can match the needs of your camshaft, cylinder head chamber, and stroker setup requirements.
Basic Custom Piston Choices
  • You name the Bore Size
  • Compression of your choice
  • Wrist Pin height adjustments
Optional upgrades
1. Custom coating: Skirts and Top
2. Wrist Pin choices
3. Pin Lock style
Other options available, contact us for any of your other ideas.
What do I need to get a custom piston done for my setup?
We need specific information to do any custom piston. As much information you can give will benefit the design of the piston.
  • Bore size. We’ll assume you want the pistons leveled with the deck, specify if not.
  • Compression desired(Some setups maybe limited in how high or low the compression will be)
  • Type of Cylinder Head used. Note if Milled or Not
  • Type of Block used.
  • Type of Crankshaft used and its stroke
  • Type of Rod used and its length. Note if using a different wrist pin width than usual.
  • Type of Fuel: Gas, Alcohol, etc.
  • Daily Driven or Race Only
  • Head gasket thickness: Using custom thickness or basic OEM thickness HG.
  • Wrist Pin type: Standard, Thicker(HighHP Boost), Lighter(All Motor)
  • Valves: Standard or Oversize(specify mm size)
  • Camshaft specifications: Provide all specs from the manufacturer.
There are other information required, but we can go through that when you’re finalizing your order.
Bore choices:
B16/B18: 81-87mm bore.
H22: 87-90.5mm bore.
D16/D15: 75-79mm bore
K20/K24: 86-90mm bore
Other applications available(F, C, D17, etc).
We have certain specs already calculated with specific camshafts, cylinder head and block combinations.
Some sample combinations:
K24/K20 Head, Skunk2 cams, 89mm, 15:1
LS/VTEC, Skunk2 Pro2 cams, 85mm 14.5:1
D16, Exospeed Stage 4 cam, 78mm, 13:1
D16, Exospeed Stage 4 cam, 75.5mm, 12:1
H22, 95mm crank, SK2 Pro cams, H22 rods, 89mm, 13:1
There are some common combinations that we've done many times that may be suitable to your setup. But if you have your own combination of parts, we can make a piston set that will work with what youre trying to achieve.
Basic Custom Pistons start at $630.00/set
* Any Bore size, compression, wrist pin height relocation, valve pocket size depth and diameter design.
* Includes standard wrist pins, wrist pin locks and ring sets.
B-series 85mm 15:1
H22 89mm 14:1
B16 81.5mm 12.5:1
D16A6 78mm 13:1
H22 89mm 14.5:1
D16A6 75.5mm 11.5:1
Old Apr 30, 2009 | 11:36 PM
Default Re: All Motor/Turbo Custom Pistons! 15:1 Whaaa?
Piston pics mostly show All Motor high compression ones but we can do Turbo compressions as well. Didnt really show much turbo pistons since they all look pretty similar with their dish or flat faced surfaces.
Old May 5, 2009 | 08:25 AM
Contact our sales department:
Best way:
Email all your information and questions - sales@exospeed.com
661-775-1963
Old May 5, 2009 | 06:38 PM
egturbolsvtec's Avatar
how much for b series vtec pistons 82mm highest compression u got
Old May 5, 2009 | 07:53 PM
What compression do you want?
Old May 5, 2009 | 08:26 PM
jdmtrdriderpr's Avatar
New User
Nice looking product!
Old May 5, 2009 | 08:34 PM
IT'S ME DAVID's Avatar
NooB
how much 86mm kseries tsx head k24a2 standard valves no mill hiigh boost application 9:0 compression or 9:5
Old May 6, 2009 | 03:39 AM
those 14.5:1 pistons but i need them in 82mm
Old May 6, 2009 | 01:33 PM
Custom pistons are $630.00 comes with the wrist pins and locks.
Old May 6, 2009 | 01:34 PM
Those are also $630.00 with wrist pins and locks.
Main things to specify are: which head youre using, camshaft specs and valve diameter sizes.
Old May 6, 2009 | 01:56 PM
Another type of custom piston we can do.
Features:
1. Hard Anodized
2. Pin buttons
Old May 7, 2009 | 07:34 AM
Best way:
661-775-1963
Old Jun 2, 2009 | 06:39 PM
mikeymcm's Avatar
nice stuff will, hope to see you on the east coast again this year.
Old Sep 20, 2009 | 12:55 AM
slowbue's Avatar
whats the highest i can go on a stock internal b18c
Old Sep 20, 2009 | 07:20 AM
Compression or bore? stock internals meaning cylinder head or using stock rods?
Old Aug 2, 2014 | 07:50 AM
low13da9's Avatar
Bringing back from dead. Still making pistons for h22?
rnomad
Sep 27, 2009 07:42 AM
flatblackracing
Jul 22, 2006 08:10 AM
