B series Valve adjustment question
Old Apr 30, 2009 | 09:18 AM
bakomack's Avatar
Default B series Valve adjustment question
I need to give my b16 a valve adjustment and I have the specs and everything but when you stick the feeler gauge between the cam and roller, which lope of the cam do you measure on per cylinder.
ie. if im doing cylinder number one on the exhaust side, which lope do I measure?
same questions for intake side.
sry but ive never done it before and im trying to learn. thanks
Old Apr 30, 2009 | 09:25 AM
ekb16's Avatar
Default Re: B series Valve adjustment question
http://www.c-speedracing.com/howto/v...alveadjust.php
Old Apr 30, 2009 | 09:37 AM
bakomack's Avatar
thanks for the post, I have read that article about 10 times.
but there are 3 lopes on the cams per cylinder. do you only need to do the primary?
thats what I dont understand
Old Apr 30, 2009 | 09:48 AM
kyden's Avatar
don't bother with the vtec lobe.
Old Apr 30, 2009 | 09:52 AM
bakomack's Avatar
ok so just primary and secondary, thanks man
Old Apr 30, 2009 | 11:27 AM
sackdz's Avatar
or maybe you can look at ait a different way... adjust using the lobes with the adjustment screws under them?
bakomack
Apr 30, 2009 01:05 PM
ludekid4323
Mar 12, 2009 09:37 PM
OnDaBottle
Oct 20, 2004 12:10 PM
Mr.Integra
Feb 25, 2003 11:22 PM
stRtypR25
Nov 29, 2002 08:49 PM
