Quick questoin about valve adjustment
Old 02-25-2003, 09:08 PM
Mr.Integra's Avatar
Default Quick questoin about valve adjustment
do i need to set the cam gears at 0,0 when doing a valve adjustment?
TIA
Old 02-25-2003, 09:13 PM
JDM CTR '00's Avatar
Default Re: Quick questoin about valve adjustment (Mr.Integra)
no
Old 02-25-2003, 09:51 PM
TypeR 599's Avatar
Default Re: Quick questoin about valve adjustment (ChargedSi99)
no
from the valve adjustment master. hey, lets redo my valves just for fun
Old 02-25-2003, 10:27 PM
Hugh Bowie's Avatar
Default Re: Quick questoin about valve adjustment (TypeR 599)
ive done mine 4 times in the past 10k
#1 at tdc
buy the special tool, or you too will do yours 4 times in the next 10k
Old 02-25-2003, 10:32 PM
New User
io_burn's Avatar
Default Re: Quick questoin about valve adjustment (Hugh Bowie)
Hmm... this reminds me to put "learn how to adjust valves" on ye olde to do list.
(Beats paying the dealer whatever ridiculous amount of money they want for it to be done... after $100 for an oil change I'm scared to ask!)
Old 02-25-2003, 10:52 PM
PatrickGSR94's Avatar
You don't even have to have the cylinder at exactly TDC. Just make sure that all the valves are closed on the compression stroke, with the cam lobes pointing up and away from the rocker arms (when any one cylinder is at TDC, the exhaust cam lobes should point up and towards the front of the car, and the intake cam lobes should point up and towards the rear of the car). You have a window of several degrees on either side of TDC that will work fine for setting the valve clearances on any particular cylinder.
I say this so you will know that you don't have to be EXACT and rotate the engine ALL the way around if you just go a little bit past TDC for the cylinder you're working on. And whatever you do, NEVER turn the engine backwards!
[Modified by PatrickGSR94, 1:52 AM 2/26/2003]
Old 02-25-2003, 11:22 PM
Nvious R's Avatar
Location: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
how often are you guys adjusting your valves? I did mine and a good 10k back. Im getting ready to hit 50k on a 2001 with Jun valve springs ( she's my snow plow too ) but i noticed the ticking gets louder. I sprung CEL 45 and i cleaned the injectors accordingly but the CEL popped up again. I read a post and it said to check the fuel pressure so i guess thats next. I wonder if that valve ticking has anything to do with the valvespring's installed height cause i know thats rather important. Anyone else having the same kinda noises? After the valve adjustment it helped a lil bit but not too much. I guess im going to try and do a valve adjustment on my car as soon as it gets warmer out. We'll see how everything goes i guess.
barrera
01-06-2010 08:57 AM
OnDaBottle
10-20-2004 12:10 PM
Turbo-Honda
10-12-2004 06:26 PM
95gsr
04-08-2003 07:20 AM
Nate B
02-17-2003 10:15 AM
Quick Reply: Quick questoin about valve adjustment
