SRS Light
alright my question is.. what would make the srs light cme on in the dashboard? could it be a fuse or the airbag itself.. i wanna get this problem solved before i drive my car, not that i plan on crashing but you never what can happen right.
thanks in advance.
thanks in advance.
dunno the real cause but you can reset that SRS light
http://www.geocities.com/myintegra96/srs.html
this will reset the SRS light if done right
im not saying to do it, im just saying it can be done
if anything bad happens, im not to blame.
Retrieving CEL and SRS trouble codes by jumping the service connector is very similar. Of course, as mentioned above, first clear the SRS code(s) to see whether it returns. If it does, then the diagrams below will help.
My SRS light has come on fairly regularly the past 4 years. The error code was always and only 8-5. 8-5 indicates the SRS module has failed.
I would reset it and it would come back on within two days. Most of the time it would only take two or three engines starts before it would come on again.
Since having my compressor clutch coil replaced (20 Jun 09), the SRS light has not stayed on. After looking at the circuit again (with an general auto tech), I don't see how one would affect the other but it is way too coincidental to ignore this as possibly related.
arsenaldragster
Apr 18, 2003 03:31 PM
