installing lower ball joints
Old Apr 29, 2009 | 09:14 PM
ryanevansoh's Avatar
Default installing lower ball joints
ok well i just got my knuckle back from napa because i had them press out the lower ball joint. now i am at installing them. so my question is how do i install them? should i just take a big hammer to it? and also, how and where does the c-clip go on? thanks
Old Apr 29, 2009 | 09:26 PM
frank_el_tanke's Avatar
Default Re: installing lower ball joints
you can take a hammer and lightly tap evenly around the ball joint until it goes all the way in. If you hit it too hard, you can damage the casing around the ball joint and damage it. Would be a lot easier if you have them pressed in at a shop.
Old Apr 29, 2009 | 09:28 PM
im patient so i can just tap them in, i want be bashing on them haha. so how about the c-clip?
Old Apr 29, 2009 | 09:40 PM
i believe the clip goes on once the ball joint is placed.. underneath.
Old Apr 29, 2009 | 09:43 PM
ok thanks for the help
Ef4doorwagon
Nov 21, 2014 03:47 PM
Kevins89notch
21
Nov 4, 2013 06:17 AM
usdmEHboy
10
Feb 4, 2009 10:27 PM
DEL HATCH
Dec 16, 2006 01:57 PM
2camsaam
21
Oct 1, 2003 07:32 PM
