blox type a on stock compression gsr
alright, i just install blox type a cams on my stock gsr with injen short ram intake. i can't reallie feel any difference, it feels the same. i'm also running stock gsr ecu. also how do you tell if the cams are blox or not?
Tuning is going to make the differnece. Blox As should show some kind of improvement. I'm not sure what they compare to in terms of OEM cams, but i know the B's are similar to the ITR cams. The majority of the issue stems from the fact that it is untuned. You can PM a few of the ECU wizards around here and tell them about your setup...they'll set up a good ECU and map for your setup. Then you can choose whether or not to tune more from there...try contacting Phearable or Xenocron
are you sure B's are similar to itr cams, i thought b's are similar to skunk2 stage 2 and A's are similar to skunk2 stage 1 which is a lil better than itr cams.
Your best bet to get exact answers is to go to the All Motor forum. I can move this thread for you if you like, just reply yes or no...From what i remember, the B's are similar to ITRs. I had looked at getting a set a while back instead of ITRs
this is correct. B's are bigger than ITR cams by quite a bit, the A's are similar to the CTR/ITR grind beings they are copies of skunk 1s
I did a little research and I had them backwards. The As are more like the ITRs but a tad more aggressive. The Bs are more aggressive yet.
- STOCK 1997-1999 ITR
INTAKE lift - 11.5 mm, duration 240 @1mm
EXHAUST lift - 10.5mm, duration 235 @1mm
- STOCK CTR and 2000-2001 ITR
INTAKE lift - 11.5 mm, duration 243 @1mm
2. Blox (no @1mm specs available)
- Type A , Tuner Series
INTAKE lift - 11.7 mm, duration 247 @ 0.05 in.
EXHAUST lift - 10.7mm, duration 239 @0.05 in.
- Type B, Tuner Series
INTAKE lift - 12.4 mm, duration 266 @0.05 in.
EXHAUST lift - 12.0 mm, duration 266 @0.05 in.
**Moved for ya
**Moved for ya
thanks, yea but mine feels gay as of right now because my vtec pressure code keeps on popping up so i won't get a good run to see if the cams are good or not.
i tried everything for the check engine light already, check wires, switch new gasket, oil level is good, i took the oil pressure switch off today and crank the motor to see if any oil is shooting out(honda-tech member said to do this) and no oil is shooting out of the vtec pressure switch location at all when i crank the motor, but when i took the vtec pressure swtich out, there were oil coming out though. what could i do next?
well this is what happen, i just pull the head off and there was a plug like the ls vtec did, so i just took the plug off and waiting to go get a new headgasket and i should hear my vtec cross over again. lolz i want to hear my vtec so bad especially with the blox type a that i just install.
Question: Did you have a baseline dyno run of your car before the cams? Just wondering what kinda gain to expect from them when u get tuned. I have a LS/VTEC that's semi-built.. just need a few things, like another intake manifold, cams, injectors, fuel rail & pump then get it re-tuned. Looking to push like 210whp @ least...fingers crossed!
no dyno yet, i just got my skunk2 intake manifold as well, everything's install as of right now, just that i'm missing the injectors insulator so my injectors doesn't sit all the way in, i'm just waiting on my injectors insulator, type r throttle cable and bracket from acura then i'll be set. i'll get a dyno tune after i get my header.
Make sure you use a tuning system like Neptune or Hondata etc and get it tuned or your car will fall flat on it's face the next time you "crack" VTEC (when you get it working again).
martyball619
Oct 24, 2006 09:07 AM
red civic standard
21
Jun 23, 2005 12:41 PM
