Expanding Foam
Old Apr 29, 2009 | 03:40 PM
civicvtec44's Avatar
Default Expanding Foam
Rusted out rear corner panel wondering if i could spray some expanding foam in the inside of the car to fill the hole. then bondo over the outside?
Old Apr 29, 2009 | 07:04 PM
Eyger's Avatar
Default Re: Expanding Foam
This will not work. It's well documented that the expanding foam that you use to fill in the gaps around doors and such retains moisture. It's make the rust worse. the correct way to do it is to cut and weld that junk out. The cheap way to do it is to cut/sand out all of the crap out, then use something like kitty hair on the inside bridging the gap, then evercoat the outside. (notice i didn't say bondo, because bondo blows.)
Edit, if you want real expanding foam, you can get something called "polyurethane AB foam" it doesn't retain moisture. So you can do that. Only problem is, it gets expensive. TAPplastics.com has it.
Integra4lyfe069
Apr 21, 2008 05:13 PM
Jonathan_ED3
May 26, 2005 08:59 AM
pbcdb
Audio / Security / Video
17
Jan 17, 2004 09:42 PM
baddboy
Sep 22, 2003 09:41 AM
Nader_D
Jul 23, 2003 08:43 PM
