EG6 LS Help: Squealing sound from engine bay 2-3000 rpm and up
Old Apr 29, 2009 | 03:07 PM
95GSRBOI's Avatar
Default EG6 LS Help: Squealing sound from engine bay 2-3000 rpm and up
I thought it was my alternator/power steering belt because that was the only thing i didnt replaced during the swapped a 1 1/2 ago. Therefore I replaced it, but I am still getting a squealing sound during deceleration around 3k rpm. It only happen after warm up. IN the morning to work I dont hear it until after 4-5 miles of driving. Anyone have similar problem? Can it be the clutch? Sounds like it coming from the belt side, but at the same time it sounds like its somewhere under the I/M. Please help
Old Sep 27, 2010 | 03:49 AM
antomys's Avatar
Default Re: EG6 LS Help: Squealing sound from engine bay 2-3000 rpm and up
Im having the same issue, from 3000-3500 my motor makes a kind of squeal noise and only in that range of rpm. Before and after its fine but i have no idea what it is its kind of annoying. Any ideas guys please help out it would be appriciated.
1997 Honda Civic HX
Old Sep 27, 2010 | 05:56 AM
EHondaJDM's Avatar
What other accessorys do you got besides the alt?
Are you running stock pulleys?
Could be your alt crapping out
Old Sep 27, 2010 | 07:03 AM
Gekko's Avatar
I had this problem on my DA integra and it was the A/C belt tensioner pulley. It was about to seize up, I could hardly turn it by hand.
Old Sep 27, 2010 | 07:16 AM
robodouche's Avatar
You can isolate the belt by spraying it with water while the engine is running. If wetting the belt kills the noise, you'll know it's the belt. This may not help if you can't get it to make the noise by revving the engine with the car standing still, as the water will most likely dry by the time you get it out on the road.
If you wet the belt and the noise doesn't change, you may have a pulley with a bad bearing.
Take the belts off and spin each pulley by hand. The pulleys should all spin smoothly with no noise or roughness. If you hear or feel anything on any of them, you have a bearing that's either shot or on its way out.
therhett17
Mar 3, 2015 04:06 AM
soclean
May 7, 2012 03:56 PM
ugly.
18
Jan 16, 2010 08:47 PM
stRtypR25
Sep 26, 2002 03:01 PM
shadowdawn
Aug 4, 2002 09:48 AM
