Brembo blank 25170 same as 25199?
I ordered Brembo rear blank rotors for 2000 integra gsr BRE-25170, but received BRE-25199. I checked the specs on 25170 and 25199 and they are little different. According to the vendor, they are comparable and Brembo does not make 25170 anymore. Is it true?
i just ordered my brembo blanks, got them in yesterday and i received the right ones. I got them from 88rotors. part number is BRE 25170 (rear)...my fronts i think read BRE 25199...so maybe they sent you the ones for the front instead of the back.
Well, I finished the installation and it worked without any fitment issue. As far as I know both rotors have the same diameter, but BRE 25199 is 1 mm thicker and hub to rotor depth is 0.5 mm more than BRE 25170 according to brembo web site. I got them from importrp.com.
The front should be BRE 25331 (vented) vs. solid rear rotors
nsimov
Mar 14, 2006 12:44 PM
tunes12
Jun 12, 2003 03:38 AM
Stryker908
10
Dec 3, 2002 06:59 AM
