LS swap into a 4dr ej6
Old Apr 29, 2009 | 01:14 PM
91integra_rubio's Avatar
Default LS swap into a 4dr ej6
i talked my cousin out of buying a bike to ls swap his 98 4dr civic. looking for some info and helpful advice before starting off. the motor will come from tigerjapanese.com. its a b18b 94+. should he be looking for a obd1 or obd2 motor? possible turbo in future so she he just go obd1 anyways? thank you any advice is greatly appreciated.
Old Apr 29, 2009 | 01:45 PM
hannslebo's Avatar
Default Re: LS swap into a 4dr ej6
OBD1. if you guys are going turbo...from what i hear OBD2 is not good for tuning.
Old Apr 29, 2009 | 01:48 PM
98civdx's Avatar
Master Detailer
obd 2 sucks for tuning cant chip the ecu.
switch it to obd 1 much easier for tuning,
Old Apr 29, 2009 | 04:32 PM
94EG8's Avatar
Seagull Management
In the name of keeping things simple get an OBD2 engine, this ensures no screwing around with alternator, distributor and injector connectors, use an OBD2A to OBD1 conversion harness and run an OBD1 ECU
Old Apr 29, 2009 | 05:31 PM
98civdx's Avatar
Master Detailer
hes right
aunt just did this in her ej6 as well
Old Apr 29, 2009 | 09:24 PM
she swapped in a b-series?
so he will need a 96 or newer motor. i searched but couldnt find one, is there a write up for putting a b-series motor in a obd2 civic?
Old Apr 29, 2009 | 10:56 PM
fastrxu's Avatar
x2 that's my exact setup
and when it comes to your anual rectal exam called SMOG CHECk you can swap ecu's and your set
white2draccord
Nov 10, 2008 08:15 PM
so simple
Mar 3, 2007 08:12 PM
VTECth1s
Jun 7, 2006 05:51 PM
ddong2lee
Jul 22, 2003 06:03 AM
