$2000???
tranny swap , and if ur car is low mileage home built turbo set up. or if you jsut want a decent daily new suspension and tires and a full tune up brakes, head gasket water pump plugs wires etc
Suspension and transmission swap. Don't throw money away at that engine until you make it manual. Honda automatic transmissions can't reliably hold any kind of meaningful power increase.
Then turbo it.
Or swap it to manual B series. I bet you could piece together a B20 swap for under 1500.
Then turbo it.
but since it has 200k miles on it now, Ill try to figure out what to do with the engine side of it.
coils- converted to manual might as well swap the engine with a b18b1 you can pic it up for 500 or so at car-parts.com an you still have money to play with...dont forget the beers while you doing it
kush purp etc. as long as i get stoned. i could not work on a car while buzzed/drunk.
but for the OP...if its your daily then def get it running good...major tune up/swap??? thats my .02...my first car i blew all my money on susp. exhaust. etc. and 2 mths later i was stuck with a blow engine.
For the love of God no wing. I would say do a swap but I assume you might not be comfortable doing it yourself. I would get suspension, wheels, and good tires if I were you. Then learn how to drive you car by doing some autoX and going to a track.
Google Hallett. Its a track not too far from you and it is awesome. I'm from AR and have friends that race there all the time.
