Leaky Roof Panel What to do????
Find the leak and seal it. If needed take the roof liner off if it has been soaked because you will most likely get mold and it should be easier to determine where the leak is coming from.
If you do take it off, sit in the car and have a friend run the water hose on the outside of the car and see if you can spot the leak.
In that case I would recommend you consult with one of those windshield companies. If it is that gummy stuff around the windshield they have some good sealant for it.
aj1500
19
Jun 27, 2017 04:03 AM
