few questions about hmotors (HELP!!)
Old Apr 28, 2009 | 11:03 PM
TweedZ's Avatar
Default few questions about hmotors (HELP!!)
so im getting pretty ancy and have been trying to find a good engine for a couple weeks now. sohc, and havent had much luck. theres a y8 for sale form a local shop for $400 but id have to buy the conversion harnesses and i think it has over 100k on it no tranny no dizzy i dont think or ecu.
i was thinking of buying a d15b off hmo and then trading my p28 for a p08 and maybe paying the additional $250 for the tranny since its all guarenteed low miles and i know they will warranty start up.
but its $550 + im guessing around $150ish to ship i tto oregon from ca. plus 250 for the tranny.
my question is should i do this? itl be about $800 total but itl be guarenteed low miles and i plan on driving my civic for a long time and staying sohc.
would my current eg dx tranny work in it?
and is this motor plug and play with obd1?
hmo says it comes with the following:
Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
- 5 Speed Hydro Tranny (Add $250)
- P08 ECU (Add $125)
what else would i need to buy to have this running? i alrdy have new axles but not sure if harness is good to go or what?
need opinions asap as i really need to get my car back on the road
Old Apr 28, 2009 | 11:28 PM
TweedZ's Avatar
Default Re: few questions about hmotors (HELP!!)
also i heard its a 1wire 02 instead of the current 4 wire i have
how tdo i change this? just buy a new 02 sensor?
and can i keep the p28 ecu and have it run good?
Old Apr 28, 2009 | 11:36 PM
DOHChatchGUY's Avatar
All I can tell you is that I've never heard anything but good things about Hmotors on this site. I know my cousin got a B20 from them and it was clean and legit. Ran strong and started right up. And your DX tranny would work but it would feel slow because of the long *** gears. If you have the cash just get the tranny for it, and if you have a little extra get it with the LSD.
Old Apr 29, 2009 | 01:40 AM
fastrxu's Avatar
get the tranny with it you can sell yours for like 100 the net price for the new tranny is only 150 not too bad
hmotors = good
Old Apr 29, 2009 | 02:11 AM
TweedZ's Avatar
it syas it comes with the following
Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
what else do i need that i wouldnt alrdy have?
would i need to buy a starter or belts? or does it normally come with one?
i want to make sure i have this priced for a COMPLETE longblock because i am extremely tight on money
Old Apr 29, 2009 | 02:55 AM
Inliner's Avatar
so from your post your original engine is a d16z6? 92-95 civic?
get the JDM D15B its a vtec engine use your p28.
yes your trans will bolt right up now is the time to replace that old stock clutch though.
get an exedy OEM replacement DO NOT buy an off the shelf clutch.
any other Q's feel free to PM me.
Old Apr 29, 2009 | 04:39 AM
PanamaRed's Avatar
H series deal alot of power, but weigh alot. The only problem with your tranny is that the gears would seem long.
Old Apr 29, 2009 | 05:00 AM
Murk 'EM's Avatar
iv had nothing but good experiances with hmo their the only place ill buy a motor from
Old Apr 29, 2009 | 05:47 AM
TweedZ's Avatar
if i buy the tranny will it come w clutch flywheel?
bumping before i go to bed (work graveyard)
what do i do about the o2
do i need to buy a starter for it or will it coem with one?
is the rest of it just plug and play?
what preinstall maint. do i need to do
Old Apr 29, 2009 | 07:19 AM
LegoZ81's Avatar
link to the motor plz i have not been playing honda guy for a while, but should be able to help...
poor hatch finally got driven after sitting in the garage all winter. I think i drove it 3 times last year
Old Apr 29, 2009 | 07:21 AM
Hatchd's Avatar
I think he's talking about hmotorsonline.com, not putting an H series into his car lol
I'm not totally sure how they do it buy usually if you buy the motor and tranny it all comes together which means it should have the clutch/flywheel there. Most people will replace because it's a whole hell of a lot easier replacing this stuff while the motor is sitting on a palette as opposed to in your car.
As far as the O2, I don't know enough to comment.
Unless I'm rusty on my honda knowledge(could be, haven't been around in about 3 years) the starter that you have now should work unless it's bad.
And it should be plug and play.
Here's my suggestion though. if you already have a P28 ecu that means you should have the z6 motor. That also means you already have the shorter geared tranny so there is NO need for you to buy the tranny with the motor. I'd buy the motor, use your trans, replace the clutch while it's not in your car, and if you want to do little stuff like a timing belt, headgasket, etc. do it all while it's out of the car. If not, drop it in and hope for the best. Also, while the motor is out, use it as a good time to clean your engine bay. when I did my swap I didn't do that and it annoyed the **** out of me.
Good luck.
Old Apr 29, 2009 | 07:37 PM
Murk 'EM's Avatar
ok yes it comes with the clutch/flywheel (if you buy the motor/trans complete) yes it comes with a starter (again if you buy the motor/trans) as for the o2 i dont remember i think it does (atleast mine did B16a/S21 lsd trans) and yes it is plug and play their was only one cut wire on mine and it was the vtec pressure sensor (wich isnt hard to wire up)
and like i said earlier i will only deal with hmotors they have the best customer service iv ever delt with and shipping is fast for what your getting
gsrhb7
Northwest (Sales)
Jun 29, 2007 02:12 AM
m0nee
Jun 17, 2007 03:46 PM
GTEC913
Aug 17, 2006 05:41 AM
eg686
Jun 25, 2005 01:46 PM
dlszrfn
17
Jan 11, 2005 04:49 PM
