Integra DC2 DIYs complete. Check'em out.
I've completed some write ups on the Dc2 Acura Integra. Let me know if you guys see any errors.
- Acura Integra DC2 B18C engine overhaul.
- Acura Integra DC2 B18C1 and B18C5 Overhaul
- Acura Integra DC2 B18c DOHC camshaft specs.
- Acura Integra DC2 DOHC camshaft removal and installation.
- Acura Integra DC2 B18C cylinder head.
- Acura Integra DC2 B18c engine removal and installation.
- Acura Integra DC2 fuel pressure release procedure.
- Acura Integra DC2 intake and exhaust manifold.
- Acura Integra DC2 oil pan removal and installation.
- Acura Integra DC2 B18C front and rear oil seals.
- Acura Integra DC2 B18c timing belt removal and installation.
- Acura Integra DC2 B18C engine torque specs.
- Acura Integra DC2 B18c valve clearance adjustments.
- Acura Integra DC2 B18c valve and valve spring specs.
- Acura Integra DC2 B18c water pump removal and installation.
- Acura Integra DC2 B18C Valvetrain....Newly added!
- Acura Integra DC2 alignment, camber, toe, caster, etc.....Newly added!
- Acura Integra DC2 clutch bleeding procedure.....Newly added!
- Acura Integra DC2 clutch pedal height adjustment.....Newly added!
- Acura Integra DC2 Clutch assemly, master cylinder, etc.....Newly added!
- Acura Integra DC2 hub and knuckly assembly.....Newly added!
- Acura Integra DC2 shocks and struts removal and install procedure.....Newly added!
- Acura Integra DC2 wheel bearings....Newly added!
- Acura Integra DC2 front axles, damper, intermediate shaft, etc.....Newly added!
More updates coming soon...
For the knuckle removal, it's much easier to just hit the notches with a hammer so it pops out. Saves for having to replace the joints to a split boot.
Am i the only one who is not impressed? Many are very superficial and basically just list what to remove.
There are much more detailed DIY's on team integra and c-speed racing.
