Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Removing Antifreeze without flush
Old Apr 28, 2009 | 05:48 PM
EM2_PLo's Avatar
Default Removing Antifreeze without flush
I recently lent my brother my car to take a trip out of town and before he took it I told him to inspect the fluid levels... The retard filled the antifreeze all the way to the max line instead of filling it between the min and max level ... Money is tight right now so I was wondering if there was a way to remove some of the fluid without draining and flushing out the system?
Old Apr 28, 2009 | 06:41 PM
toyomatt84's Avatar
Sanji
Default Re: Removing Antifreeze without flush
A turkey baster will draw out the excess fluid.
Old Apr 28, 2009 | 06:43 PM
Dogginator's Avatar
Daisy... Daisy...
You can also easily remove the coolant overflow bottle. It will slide up and out of the bracket.
Old Apr 28, 2009 | 07:20 PM
Sr420Det's Avatar
or just use the radiator drain plug or just leave it in there wtf? the worse that could happen is it overflows
Old Apr 28, 2009 | 07:22 PM
EM2_PLo's Avatar
Thanks dogginator but I'm thinkin of just taking Toyomatt's advice, seems like a lot less work... Thanks a lot
Old Apr 28, 2009 | 07:45 PM
Harlowe's Avatar
Function>Fashion
7thgen coolant overflow bottle is held on by 2 10mm bolts. Still, really easy to take off, I've done it plenty of times.
Old Apr 29, 2009 | 08:24 AM
lowlife9's Avatar
i just did the same thing but you can't fit a turky baster in the overflow tank i just bought a siphon pump from wal-mart for 3 bucks it works perfect.
Old Apr 29, 2009 | 09:28 AM
EM2_PLo's Avatar
That's ironic!!! I just got back from wal mart and bought the same thing... It worked! Thanks for all the help guys... I greatly appreciate it.
Old Apr 29, 2009 | 10:56 AM
Boilermaker1's Avatar
You could just leave it alone... I highly doubt you're going to push coolant from the max line out the top of the overflow.
CRISIS
Jan 6, 2007 10:45 AM
Knight1
Mar 21, 2006 12:24 AM
blulude92
Jul 11, 2005 06:00 AM
Mattyg2
May 21, 2004 07:23 PM
TurBoXBirD16
Jun 5, 2002 04:54 AM
