weird engine squeak
Old Apr 28, 2009 | 02:36 PM
dtarvin's Avatar
Default weird engine squeak
just checkin for ideas...
i have a weird squeak coming from the engine bay, sounds like it's on the back side or around the mount. i've since replaced the rear mount, and the squeak is still there. when i throttle the squeak pulses faster then slows down as i release throttle.
when i press on the clutch at all, the squeak goes away. it's driving me crazy.
Old Apr 28, 2009 | 02:38 PM
RunninEg6's Avatar
Default Re: weird engine squeak
belt tension?
Old May 1, 2009 | 03:37 PM
dtarvin's Avatar
i don't think it's a belt because the squeak/chirp goes away completely when i press the clutch in at all.
maybe a bearing or something in the transmission? any way to really check without pulling the transmission off?
Old May 1, 2009 | 03:52 PM
Former User's Avatar
Probably a bad input shaft bearing in the transmission.
Old May 1, 2009 | 03:59 PM
Randomluck's Avatar
Throw out bearing is bad.
Old May 1, 2009 | 04:48 PM
hondavtecsi1's Avatar
can you post a video of it with sound check if it does it when u get on the throttle a little
Old May 1, 2009 | 05:07 PM
EK9r!der's Avatar
it sounds like the throw out bearing might be going bad.
Old May 1, 2009 | 05:54 PM
A bad throw out bearing would produce noise when the clutch pedal is pushed.
Old May 2, 2009 | 04:21 AM
Randomluck's Avatar
Nope but thanks for playing. It squeaks when it's free spinning with minimal load. When the clutch is depressed it put the max load on the bushing. The pressure changes what you hear from a high pitched squeal to a low grade rumble that easily gets lost in the engine noise. It gets worse as the bearing gets ready to give its final spin and then you may or may not hear it.
Old May 2, 2009 | 06:14 AM
...It squeaks when it's free spinning with minimal load. When the clutch is depressed it put the max load on the bushing. The pressure changes what you hear from a high pitched squeal to a low grade rumble that easily gets lost in the engine noise. It gets worse as the bearing gets ready to give its final spin and then you may or may not hear it.
This explanation seems plausible, though it would represent a rare situation. Your explanation also generally conflicts with the majority of forum threads that describe how to diagnose clutch and transmission noises. This thread is just one of many examples.
peterphn
Transmission & Drivetrain
Oct 26, 2012 11:56 AM
Sorcin
May 18, 2010 09:24 PM
spens 91 Ef
29
Mar 8, 2009 08:15 AM
pelotudo
Jun 20, 2002 02:11 PM
BoM
Mar 14, 2002 08:20 PM
