No spark
Old Apr 28, 2009 | 01:40 PM
JScott3d's Avatar
Default No spark
I just did a ZC swap into a buddies CRX. The swap went well and all. It cranks but I am not getting spark. I do not think that its the dizzy as I have tried 3 different ones all known to be good. One came off my car. I also tried the stock SI ecu and an ecu out of an 89 Integra but none did anything different. Any ideas would be helpful. I used this as a reference http://www.phatwhippincrx.20m.com/photo6.html
Old Apr 28, 2009 | 06:11 PM
redflaredcrx90's Avatar
Default Re: No spark
is the car an si . if no spark check main relay check ecu fuse under hood
Old Apr 28, 2009 | 08:00 PM
JScott3d's Avatar
it is an si. new main relay and all fuses are good. the car ran before we pulled the motor and the zc ran before it was pulled. what dizzy do I need. that was the only thing that the guy kept. I have one for a 89 Integra.
Old Apr 29, 2009 | 06:10 AM
jlicrx's Avatar
do you have the Si engine harness on it? is the ground wire, coming out of the engine harness, connected at the thermostat housing? do you have any codes showing on the ECU?
the 88-89 Integra distributor is the same as the DOHC ZC
Old Apr 29, 2009 | 07:06 AM
JScott3d's Avatar
I do not know if its an hf or si engine harness and body harness. my buddy could not which harness he has. his crx was a dx sor he picked up a shell and engine harness from 2 different ppl on ebay. and he is unsure if they are from the same model.
Old Apr 29, 2009 | 08:39 AM
JScott3d's Avatar
well its all an si harness harness. I have power to the dizzy and to the coil just nothing past there. I have tried 3 different dizzys and not one works and one is off my daily and I know it works. Any ideas would be helpful.
Old Apr 30, 2009 | 04:53 AM
JScott3d's Avatar
anyone
Old May 3, 2009 | 09:19 AM
streetfame973's Avatar
im having the same problem i have no spark on my swap i have no idea wat it is someone help us out
Old May 4, 2009 | 07:29 PM
JScott3d's Avatar
bump
Old May 9, 2010 | 07:56 PM
cherroneballs's Avatar
I am also having the same issue with my 91 crx si
Old May 9, 2010 | 08:25 PM
D16SiHatch's Avatar
if the car is a dx and you have an si engine harness installed then that's your problem. you would need to get a dx harness and convert it to mpfi.
i presume you are throwing some codes correct? and i'd be willing to bet, if the above is true, that you have a code 4 and 9 for the crankshaft position and cylinder position sensors respectively. the dpfi cabin harness is guiding the CYP wires to the CKP sensor, and the CKP input at the ecu is going nowhere.
jrnsr
Oct 8, 2011 10:08 AM
1990crx
11
Jun 9, 2007 06:15 PM
h22_crx
Aug 16, 2005 07:31 AM
chirp2hrd
Feb 23, 2003 03:33 PM
ICC96INTEGRA
Jun 18, 2002 07:27 AM
