Quick question about shift linkage bar
Old Apr 28, 2009 | 12:53 PM
WeB's Avatar
WeB
Icon2 Quick question about shift linkage bar
So I had my hatch up in the air today because it was giving me problems gettin into all the upper gears. I checked the shift linkage and noticed the bar is bent and rubbing the stabilizer bar next to it. If I heat up the shift linkage with a torch to bend it back to where its supposed to be, will that hurt the integrity of the metal or do damage do it? It's not bent badly, just enough to be touching the other bar.
Old Apr 28, 2009 | 05:25 PM
Agent Smith's Avatar
Default Re: Quick question about shift linkage bar
It shouldnt hurt just dont put to much heat on it.
Old Apr 28, 2009 | 07:04 PM
xaine's Avatar
if it were me
i would remove the whole shifter linkage assm
and use a press or maybe a vice
but heating it with a torch shouldnt hurt if you dont heat it up to much.
but when you go to bend it back you could damage bushings or other stuff
you will definatly burn off the coating paint.
make sure to paint back over it to reseal the metal
Old Apr 29, 2009 | 10:59 AM
WeB's Avatar
WeB
Alright, thanks, will give it a try
Old Feb 28, 2010 | 03:35 PM
edstone83's Avatar
How did it all work out?
Old Feb 28, 2010 | 04:26 PM
Clipsed's Avatar
Happened to my buddy, we left it on, used a small jack to bend it back, worked perfectly.
Alicali
Nov 30, 2016 02:57 PM
Cookiegsr
Apr 26, 2009 02:40 PM
Full-Race Geoff
Jan 27, 2004 08:18 PM
99YZF
Nov 8, 2002 11:18 AM
karmannghia
Nov 18, 2001 06:24 PM
