Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Fog light problems!! Please help
Old Apr 28, 2009 | 12:28 PM
tomii.dc-5's Avatar
Icon6 Fog light problems!! Please help
ok i've installed these foglights with and oem kit and still its a no go with getting them to work.
ive checked all the ground bolts and i ran a hot through the 1 pin connector (see picture)
and the lights turn on so i know it has to be something wrong somewhere in the switch harness. so now im stuck i have everything hooked up perfectly so i was trying to mess with the harness and relay to see if i could figure out the problem i took a hot ground wire i hooked from my battery and was touching and test the wires tiring to see what gets the light to turn on . when everything is hooked up and i touch all the wires on the relay with my hot/ground wire it urns on the light! but when i take it off it stays on until i turn the switch off (as it should) but when i try to turn it back on with out the wire i have connected to the battery it doesnt work. but if i leave the hot/ground wire on the relay the light stay on even if the switch is off and even when the car is off.
i know this is really confusing but if someone can help me it would be greatly appreciated let me know if you need any clarification because again this is confusing as hell
Old Apr 28, 2009 | 03:26 PM
Zeusone's Avatar
Default Re: Fog light problems!! Please help
did you put the fuse in the number 6 slot?
Old Apr 28, 2009 | 09:31 PM
tomii.dc-5's Avatar
yes i did
Old Apr 29, 2009 | 03:32 AM
ironworker's Avatar
What year is your civic?
Old Apr 29, 2009 | 10:12 AM
tomii.dc-5's Avatar
08 civic coupe EX-L
Old Apr 29, 2009 | 03:24 PM
Zeusone's Avatar
bad relay?
Old Apr 29, 2009 | 06:09 PM
ironworker's Avatar
Did you plug the 2 wires that go under the fuse box in the correct holes?
Old Apr 29, 2009 | 08:06 PM
miketat594's Avatar
Make sure you got the wires in the correct fuses..
Old Apr 29, 2009 | 09:52 PM
tomii.dc-5's Avatar
yes i plugged the two wires in and i follow these directions exactly:
http://www.hondapartsdeals.com/honda...Fog_Lights.pdf
and doubled the checked the steps with these directions:
http://www.clubcivic.com/board/showt...ight=fog+light
Old Apr 29, 2009 | 09:53 PM
tomii.dc-5's Avatar
bad relay?
how can i tell if its a bad relay?
Old Apr 30, 2009 | 09:26 AM
ironworker's Avatar
I followed those 1st set of directions you posted and everything on myne worked. Which switch do you have? The one on the steering colum? The relays are around $10-15. You should go buy one and see if yours is bad. What size fuse did u put in the #6 slot?
Edit: Part # for relay is 39794-SDA-A05. I have an extra on but it would probly cost less to buy one rather than ship it.
Old Apr 30, 2009 | 11:26 AM
tomii.dc-5's Avatar
i have the switch that goes in the dash (see picture) and i used a 20AMP fuse
will honda cover a bad relay?
Last edited by tomii.dc-5; Apr 30, 2009 at 11:28 AM. Reason: forgot to add something
Old Apr 30, 2009 | 05:59 PM
ironworker's Avatar
Mabey its a bad switch or just a bad relay. If you have followed the DIY step by step it should work. Try a 30 amp fuse in the #6 slot. Try to take your relay up to honda and have them test it for you. Idk if they will or not but its worth a shot. If nothing else PM me and i can mail you my other relay.(new still in the orignal pakage)
Old Apr 30, 2009 | 10:27 PM
tomii.dc-5's Avatar
ok im going to honda tomorrow to try and figure it out thanks ill post up what they tell me
Old May 3, 2009 | 01:02 AM
Point4Dave's Avatar
The most common problem is the brown connector by the washer fluid tank. A lot of people have a hard time getting it to "click". Because I waited a year before installing OEM Fog's, dirt got up into the connector so I couldn't get it to click. I mashed as hard as I could on it, then siliconed it, lol. worked like a charm. Try mashing that connector w/ the lights on to test. Otherwise you prolly have a bad relay.
hardrock2401
Oct 13, 2013 06:50 PM
fwdftw
Aug 21, 2006 05:42 PM
Bone Stock
Audio / Security / Video
Aug 18, 2004 02:24 PM
nevin
Aug 8, 2003 11:27 AM
