nobody really answered.. WILL code 41 (o2 sensor heater) make vtec not hit??
Old Apr 28, 2009 | 10:33 AM
JoshJosephKeith's Avatar
Default nobody really answered.. WILL code 41 (o2 sensor heater) make vtec not hit??
Im told it wont make vtec stop working by a few people then Im told it will!??? When I start the car.. the CEL pops up a second later.. pulls code 41.. Pretty sure Im not hitting vtec.. My exhaust is off so I should hear vtec engage pretty good.. even with a stock ecu
Old Apr 28, 2009 | 10:50 AM
4drEF's Avatar
Keyboard Humorist
Default Re: nobody really answered.. WILL code 41 (o2 sensor heater) make vtec not hit??
I thought that oil pressure or a limp mode condition were the only things that would stop it from activating.
Then again, why not just fix the O2 problem and see if vtec comes back?
Just curious, do your neighbors give you dirty looks when you drive around with no exhaust?
(One other thing - vtec won't engage if you are just revving the engine and not driving around)
Old Apr 28, 2009 | 10:52 AM
slowassBubble's Avatar
if it goes on limp mode the vtec wont activate
Old Apr 28, 2009 | 11:17 AM
93formula's Avatar
im pretty sure an cel will not allow you to vtec, so fix your cel and let us know
Old Apr 28, 2009 | 04:29 PM
im just asking.. and wth? um i think i know vtec wont engage just reving it up?? wth you take me for .. jerk ;-) .... and yea my neighbors do give me dirty looks.. I just give em the finger.. as to anyone who gives me a dirty look. And i have exhaust.. just straight pipe.. i just did the swap and know nothing about jumper harnesses so i dont know where to start to fix the problem.. hopefully just replacing the o2 sensor will fix it..
Old Apr 28, 2009 | 04:58 PM
ef-hatchcrap's Avatar
Code 41 will not cause no vtec. There has to be something else wrong what is your setup and in what car?
Old Apr 28, 2009 | 06:30 PM
redflaredcrx90's Avatar
dude you got a cel light and cannt hit BE CAUSE WHEN VTEC HIT YOU NEED TIMING, FUEL AND OIL PERSURE. 41 DEAL WITH AIR FUEL RIGHT YES IT DOES .THE ECU READS THIS AND TELLS IT SELF THERES SOMTHING WRONG . AT HI RPMS VTEC NEED TO MAKE ADJ WITH AIR FUEL AND TIME ALL AT THE SAME TIME THAT Y YOU HAVE AN O2 SENOR IF READINGS ARNT RIGHT THE CAR RUNS LIKE ****.
Old Apr 29, 2009 | 02:11 PM
Why dont you try not typing in caps!! Nobody likes you
Old Apr 29, 2009 | 07:35 PM
~sp33~'s Avatar
EFB055
Someone helps and you call them a jerk? How are we supposed to know if you knew if VTEC wouldn't engage just by revving it up. We'd think you'd know whether a code 41 would prevent VTEC from engaging then.
No paragraphs is almost worst then caps lock.
Old Apr 30, 2009 | 04:27 AM
sorry bout the caps but was tring to make a point
Old Apr 30, 2009 | 04:33 AM
dephtone's Avatar
VTEC will not work atleast in my expierence if there is a problem with fuel or oil pressure/oil level.
Old Apr 30, 2009 | 06:29 AM
Vtec will a activate if you are throwing an o2 code. Your car will be boggy and not run to its full potential though as a result. I just fixed my o2 sensor it was throwing a code 41 and I had vtec all day I just got shitty gas mileage and bad throttle response
Campin Cracker
K Series
Dec 5, 2014 06:27 AM
vietblood87
Jul 14, 2007 09:58 PM
HUYNH
Aug 2, 2006 01:00 AM
UNDER PRESSURE
Jan 8, 2005 05:05 PM
JDM-SHREK
Nov 8, 2004 07:36 PM
