Which alternator will fit?
Old Apr 28, 2009 | 06:12 AM
jdmcivic1's Avatar
Default Which alternator will fit?
I have a 94 Civic with a second-gen JDM B16A. Recently when I start my car there is a squeak and whine that comes from the alternator. It's only for a few seconds and happens every so often. Is my alternator going bad? If so, what year alternator should I get to replace it? Will any DOHC alternator fit? Looked online and the 95 Del Sol DOHC is more expensive than a 99 SI alternator. Just trying to find the cheapest and most compatible alternator for my engine. Please let me know. Thanks!
Old Apr 28, 2009 | 06:13 AM
Inliner's Avatar
Default Re: Which alternator will fit?
any 0bd1 B series alternator, assuming your harness is 0BD1 if your harness is 0BD2 you'll need an 0BD2......
Old Apr 28, 2009 | 06:28 AM
philosofy1's Avatar
Originally Posted by jdmcivic1
I need to replace my alternator in my 94 Civic with a b16. Will any DOHC- vtec alternator fit? Please let me know. Thanks!
if you have a JDM b16 no not anyone. Unfortunately they came with weird brackets.
you will need a alternator from a 90-93 integra.
Old Apr 28, 2009 | 06:30 AM
Unseen Racer's Avatar
and as mentioned before.
any b series alternator will fit given that it is NOT a jdm b16
Old Apr 28, 2009 | 07:08 AM
thumper64's Avatar
If you have a D series on hand, it can work, at least for a temporary fix. The upper bracket may need to be ground a bit on the upper lip of the channel the bolt slides in.
I did it, it's not the best solution, but it got me to work until my new alternator arrived.
Old Apr 28, 2009 | 10:43 AM
jdmcivic1's Avatar
yes it's a JDM b16.
Old Apr 28, 2009 | 01:21 PM
jdmcivic1's Avatar
Yeah it's a jdm b16. From the 90-93 integra would i be able to use the LS alternator or just the vtec one?
Old Apr 28, 2009 | 07:25 PM
sir_warrior's Avatar
aks for a 94 del sol with dohc vtec or try this
http://cgi.ebay.com/ebaymotors/INTEG...ehicleQ5fParts
Old Apr 29, 2009 | 06:01 AM
jdmcivic1's Avatar
is my alternator going bad from squeak and whine? if so, this alternator would be a good replacement.
Old Apr 29, 2009 | 11:25 AM
philosofy1's Avatar
yes it will work. you can take the old alternator off and they will cross reference the part number and it's the same. i've changed mine 3 years ago and i've had no problems.
Old Apr 30, 2009 | 10:40 AM
jdmcivic1's Avatar
so is there a difference between 90-93 integra, 95 Del Sol DOHC, or 99 Civic SI alternators? Would any of them fit on my jdm b16 with any problems?
jeck_bar2
Feb 21, 2009 05:08 PM
ITR198
Honda S2000
Jun 18, 2008 04:13 AM
traxxasx
Mar 24, 2008 12:07 AM
hamman-25
Jun 1, 2006 02:25 PM
