Rear disc conversion!
Old Apr 28, 2009 | 05:35 AM
92hondaswap's Avatar
Default Rear disc conversion!
Hi I have a 96 Civic 4dr. and I like to know what rear Disc Conversion i need to get for it? from what model Acura and yr??? thank you!!
Old Apr 28, 2009 | 05:49 AM
99JDMHATCH's Avatar
Default Re: Rear disc conversion!
94 and up
Old Apr 28, 2009 | 05:55 AM
TOMMYASWINEY's Avatar
yeah i got my rear disc for my 92 eg from a 95 teg....works perfect....got everything pretty cheap out of a yard here in town! junkyard ftw
Old Apr 28, 2009 | 06:03 AM
99JDMHATCH's Avatar
^^^ how long did it take you to remove them from the teg. Thinking about doing the samething and going to the junk yard
Old Apr 28, 2009 | 07:24 AM
EL Vap133's Avatar
Use the 99-00 Si rear disc brakes, the e-brake cables from it are a perfect fit.
Old Apr 28, 2009 | 10:04 AM
ok thanks I will try and find 99-00.. So I guess I don't have to change the Ecable and just keep the one I have..
Old Apr 28, 2009 | 11:24 AM
B18CivicEJ8's Avatar
No, you will have to get e-brake cables from the 99-00 Si, as well. Your drum cables will not work.
Old Apr 28, 2009 | 11:27 AM
rick_rabies's Avatar
I'm not Rick!
rear disc conversion...sux...good luck. all my bolts broke
I'm not Rick!
i would suggest soaking all the bolts and nuts before you do anything
Old Apr 28, 2009 | 11:54 AM
jptyper's Avatar
start spraying with PB blaster now and do it for at least a month and you might have to cut the frame open... i did. Make sure you use a ex master or a integra master
Old Apr 28, 2009 | 11:57 AM
EL Vap133's Avatar
No, you cannot use your drum e-brake cables for rear disc brakes.
Old Apr 28, 2009 | 12:01 PM
FearTheH's Avatar
X2, its a crap ton easier if you have another vehicle to use and you have the time to pull the trailing arms off, chances are your not going to get the torx head bolts that hold the disc brake assembly to the control arm off without breaking them, be prepared to drill the bolts and retap the holes... i just had to replace my LR trailing arm and i got one from a junkyard from a 96 EX and had to swap all my Si stuff to it. luckily i drilled the bolts out just enough to barely leave their threads in the hole, ran a 10mm tap into the holes and it knocked the leftover bolt threads out, replaced with standard head bolts of the same size and thread and perfect! about all i can say now is... Have fun! LoL oh yeah, make sure you soak the large nut oh the rear of the trailing arm in the center of the 4 torx bolts with PB Blaster
Old Apr 28, 2009 | 12:03 PM
FearTheH's Avatar
why in the hell would you cut the frame? lol theres no frame, its a unibody. but why did you cut!?
Old Apr 28, 2009 | 12:10 PM
I'm not Rick!
he cut holes in the unibody to get to the threads that needed soaked, cuz the bolts are usualy rusted super bad inside.
Old Apr 28, 2009 | 12:17 PM
FearTheH's Avatar
i know hes not talking about the torx head bolts... if he had to cut to get to those he's a retard
Old Apr 28, 2009 | 01:57 PM
I had this done already on a 92 civic Hatch before and I didn't have any broken bolts or anything like it, maybe i got lucky.. All that cutting frame sounds like you didn't know what you was doing or didn't have the right tools.. good brand tools make a big dif, more torque wit power and they come off easier... anyway thanks for all the info guys!!
Old Aug 17, 2009 | 01:36 PM
badluckrex's Avatar
any one know the torque specs for those torx bolts? helms manual doesnt mention it. i guess they dont want u taken them off.
Bambooseven
Sep 22, 2010 03:59 PM
Djole_V
38
Oct 6, 2006 01:37 PM
Steak84SS
Jun 25, 2004 08:07 AM
fucT
Oct 15, 2003 07:37 AM
