1000 cc injectors big enough
Old Apr 28, 2009 | 03:59 AM
Mr Rex's Avatar
Default 1000 cc injectors big enough
looking for injectors and like the looks of the image dynamics but they only come as big as 1000. will they be big enough if im looking at the 340 whp range??
My set up is as follows
sleeved h22 stroked to a 2.7l
bore89.5 mm
15.0 to 1 comp
port flow head
custom grind crane rollers
60 mm kinsler itbs
Old Apr 28, 2009 | 04:27 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: 1000 cc injectors big enough
Yes, they will be big enough.
Old Apr 28, 2009 | 04:29 AM
Chris Tune's Avatar
even for methanol
Old Apr 28, 2009 | 04:32 AM
mar778c's Avatar
Community Builder
Originally Posted by Chris Tune
even for methanol
****, your right. My bad. OP if you are running meth then you will need 1600.
I was thinking vp16.
Old Apr 28, 2009 | 05:03 AM
kyden's Avatar
you can get ID injectors in 530cc, 725cc, or 1000cc
Old Apr 28, 2009 | 05:32 AM
tony1's Avatar
Your best bet is running the ID1000's at high fuel pressure. You can get up to 1525cc/min out of them and the increased pressure will improve atomization even further.
Old Apr 28, 2009 | 05:36 AM
scmil95eg's Avatar
You have to fuel crank horsepower, so lets say there's 18% dt loss. 340 x 1.18 = 401.20 crank horsepower
N/A Methanol:
400 x 1.1 = 440 / 4 = 110.0 + 15% = 126.5 lb/hr @ 45 psi @ 85% duty (1331 cc/min per cylinder)
N/A Gas:
400 x .48 = 192 / 4 = 48 + 15% = 55.2 lb/hr @ 45 psi @ 85% duty (581 cc/min per cylinder)
Old Apr 28, 2009 | 06:03 AM
2fastGSR's Avatar
King of the One Liners
Ken, We use them on my car as well as the 2.5L K, Duty cycle is insanely low.
The 1000s will be perfectly fine.
Whats going to benefit you is the massive fuel pump you already have, that will be killer with the IDs. . . You wil llike them a lot . .
Old Apr 28, 2009 | 06:47 AM
Mr Rex's Avatar
perfect thanks guys. tony i will be in touch later this week for a purchase.
Old Apr 28, 2009 | 07:03 AM
GhostAccord's Avatar
Hey Ken how is the beast coming along? Plan on making any runs at the Chi this summer?
May 15th, 16th & 17th maybe, or Aug 21st, 22nd, & 23rd?
Old Apr 28, 2009 | 12:13 PM
Mr Rex's Avatar
may will be pushing it but we will see, probally in june for the first quick 8 race. might tey to go to tronoto the end of may for the cscs event
Boostedjay
Jan 31, 2010 01:32 PM
Briyumbero
Nov 13, 2008 05:24 AM
eg:R
Sep 12, 2006 10:31 AM
ATS*Mark
Aug 18, 2004 09:16 PM
95c1v1cs1
Feb 10, 2003 07:09 AM
