how low should i drop my integra
i have a 95 gsr...i'm thinking about dropping it 2 inches but i don't know how low would that be..the car is my daily driven cars and i have to be making it over those speed bumps at school my car is stock height right now so can anyone give me an idea on how low 2 inch drop is? thank
ive got mine droped like 1.5 in the front and 1.2 in the back on tein basic coilovers with 17's. i love it. it looks really good and i can go over speed bumbs without going sideways.
Dumping your car is bad in every possible, conceivable way except for looks, and that's if you even like the way they look (I don't...). A 2" drop is good, and you shouldn't have any problems going over speed bumps if you have decently stiff springs.
Search around in the suspension forum just to look at different peoples' setups and see what you like.
i'm dropped 2" all the way around on tokico springs and struts, with 15" rims and 205/50 tires, it doesn't tuck tires but the gapping is about a fingers width.. honestly i want lower, probably when this suspension is worn i will go with skunk2 coilover setup so i can tuck tires some.. just looks better like that to me, but with my current setup speed bumps are ok, but i have to hit inclines at an angle, or else you will have a big flat spot on the bottom of your header like i do...
however low you wanna go. think about the condition of the roads you will be driving on. you don't want it too low, and cause you more harm than good.
You should be fine with a 2" drop but depending on the speed bump size. But a little angle attack shouldn't be too much trouble. You just need to learn how to drive with the drop.
thanks alot guys for the tips i'm planning on dropping my car 2 inches all around on some skunk2 lowering springs that i found for a bill thanks
yeah, I bet! Your suspention is probbably crapping out already...Don't listen to this guy don't dump your car...You will kill all your suspention components this way...try like .5 or .75 drop, keep it safe! Besides cars that are that low, handle like $hit!
looks good, but handles like ****
