How Do I Detect Vacuum Leaks?
Old Aug 16, 2002 | 11:17 AM
diymarc's Avatar
Default How Do I Detect Vacuum Leaks?
Got idle and emissions problems on an '88 accord. Found the easy ones (hoses rotted in half) but I hope there's more, or else it's the emission control parts, the ECU, or maybe the carb itself.
Can anyone suggest tricks to finding vacuum leaks?
Thanks,
Marc
Old Aug 16, 2002 | 11:32 AM
Nick M's Avatar
Default Re: How Do I Detect Vacuum Leaks? (diymarc)
replace all the vacuum lines
Using some soapy water brushed onto a vacuum line can sometimes work.
Old Aug 16, 2002 | 01:28 PM
Chiovnidca's Avatar
Spray around with some crab killer looking for the idle speed to pick up when you hit a leak.
Old Aug 16, 2002 | 01:57 PM
Accord94DX's Avatar
Default Re: How Do I Detect Vacuum Leaks? (Chiovnidca)
hhahahahahahahhahahahah!!!!!! awesome name!
Old Aug 16, 2002 | 02:08 PM
Brandon's Avatar
Life is Suffering
Default Re: How Do I Detect Vacuum Leaks? (Accord94DX)
Or just use some ether spray.
Old Aug 17, 2002 | 10:08 AM
fixhondas's Avatar
Check your PVC valve.
Old Aug 17, 2002 | 02:12 PM
mailforjon's Avatar
Default Re: How Do I Detect Vacuum Leaks? (fixhondas)
lol. might want to check the PCV valve rather. unless, of course, you have some white plumbing piping under your hood. in which case, you might in fact have a PVC valve of some sort. which reminds me, i once ran into a car for sale in which the owner had created a CAI using some PVC piping, a few metal bands, some rubber grommets, and a generic high flow cone filter. make me laugh. i didnt buy the car, thats for sure.
Old Aug 18, 2002 | 01:51 PM
fixhondas's Avatar
Default Re: How Do I Detect Vacuum Leaks? (mailforjon)
Yeah- PCV valve- no ****. You get the idea.
Old Aug 18, 2002 | 02:23 PM
diymarc's Avatar
Thanks folks. PCV will do. Crab killer? How about anything else that might be flamable?
Marc
Old Jul 28, 2004 | 09:09 PM
kihun_cha's Avatar
does aftermarket intake has a PCV too?
steelhitman1245
Nov 23, 2011 12:30 PM
DA3
Sep 6, 2008 09:40 PM
98IntegraLSNonVtec
May 23, 2006 05:29 PM
fe519
Nov 26, 2002 01:13 PM
xXsarcasmXx
Jul 14, 2002 11:26 PM
