Double-checking parts required for SH ATTS to Base Conversion
Old Apr 27, 2009 | 02:46 PM
Don Jefe's Avatar
Default Double-checking parts required for SH ATTS to Base Conversion
Hey everyone,
This thread over @ preludeonline (http://www.preludeonline.com/f60/sh-...l-swap-232989/) specifies what's needed in order to perform this modification. Because search has been nerfed, I just wanted to double check with you guys. As far as I can tell, and using the info prelude1897's post in that thread, all i need is:
-Base model half/intermediate shaft
-Custom fab a brace for the half shaft to be attached to
SH axles can be reused, the SH ecu will work (just unplug the atts computer) and the tranny and motor are totally compatible.
Please let me know if I've gotten something wrong or there's something that I've forgotten. I'm looking to order parts in the next couple of days. Thanks!
Old Apr 28, 2009 | 05:01 PM
snobordboy's Avatar
Moderator
Default Re: Double-checking parts required for SH ATTS to Base Conversion
The SH pass side axle will work, but you need a base model drivers side axle along with the intermediate shaft. Otherwise you should be good to go.
LeeMajors19082
Oct 3, 2016 05:30 AM
rotaryjunky
May 20, 2015 10:47 PM
dc2ls-vtec
Oct 12, 2009 12:27 PM
slow96coupe
Mar 7, 2008 01:59 PM
lacking vtec
Feb 13, 2006 12:42 PM
