91 Civic DX Service Connector Problem.
Old Apr 27, 2009 | 02:15 PM
SLowCrx's Avatar
Default 91 Civic DX Service Connector Problem.
I recently installed a DOHC ZC into my 91 DX hatch. Im running a PM6 Ecu. Everything is running really good except the service connector under the passenger side dash will not activate my CEL. Im trying to set the Distributor timing and cannot get the CEL to come on with it jumped. I know the CEL works because it comes on with the key and I had a VSS code before that I fixed (damn speedometer cable). The plug has brown and green/white stripe wires. Ive tried everything and I know im getting a good connection between the wires. Would converting from DPFI to MPFI have anything to do with it? Im not having any other issues with the swap other than this problem. Just trying to make sure the ignition timing is on point.Thanks for the help...
Old Apr 27, 2009 | 02:50 PM
jlicrx's Avatar
Default Re: 91 Civic DX Service Connector Problem.
your CEL won't come on if you jumper the ignition timing connector
Old Apr 27, 2009 | 03:57 PM
SLowCrx's Avatar
I guess im just so use to obd1. This is my first EF. So how can you tell if it is making a connection?
Old Apr 27, 2009 | 04:01 PM
SLowCrx's Avatar
Also have another question.... Is it worth it to find a PM7 or PG7 ecu? Does it make a difference? I know running the correct ECU will be better but is it worth tracking one down? If so should I go with a PM7 or PG7 ? I have a 89 PM6 and those cannot be chipped correct?
Old Apr 28, 2009 | 07:42 AM
SLowCrx's Avatar
Ttt
Old Apr 29, 2009 | 05:02 PM
JOE BD-0's Avatar
Originally Posted by SLowCrx
Also have another question.... I have a 89 PM6 and those cannot be chipped correct?
correctamundo.
tmdctfan
Mar 9, 2011 04:42 PM
strugler
May 2, 2010 05:24 PM
turbogenetic
Apr 15, 2009 09:55 AM
j_max420
Sep 4, 2004 06:35 PM
