is CF lips repairable?
Old Apr 27, 2009 | 11:02 AM
PowerLeg's Avatar
Default is CF lips repairable?
title,
i have a broken spoon lip for cheap
and i want to fix it somehow and use it
has cracked parts nad holes on the bottom side
and one of the sides at bumper edge is lumped off
Old May 9, 2009 | 06:13 PM
PowerLeg's Avatar
Default Re: is CF lips repairable?
bump
Old May 9, 2009 | 08:06 PM
Eyger's Avatar
It all really depends on how badly it's damaged. If the fabric is torn or damaged. Chances are you won't be able to fix it to look perfectly the same. If the resin is just cracked, then you might be able to sand some it out carefully and lay resin in there. And then sand and buff, clear it. If you have pictures I might be able to help you tell you how to fix it. Worst case scenario, you can just repair it with fiberglass and then paint the whole thing.
Old May 10, 2009 | 10:59 AM
Poppnfresh7's Avatar
+1
Fiberglass resin can be used to fix the cracks. Fiberglass mat can be used on the inside of the cracks to reinforce the patch job. Make sure to thoroughly clean and scuff the surfaces you plan to bond.
Old May 11, 2009 | 12:30 AM
PowerLeg's Avatar
doing my overloaded assignments before semester end...
i'll try to post some pics tomorrow
Old May 12, 2009 | 06:07 PM
phill19's Avatar
good luck i have a damaged cf hood wit jus lines no cracks u can feel the ruff spots when u rub it
Old May 13, 2009 | 01:28 PM
KuEy's Avatar
fiberglass resin and there's plenty of epoxy stuff out there. you'll have to paint it, so it wont have the CF look, but you'll still have the lip.
DynastyRacer22
Paint and Body
Jul 24, 2008 09:42 AM
cilvia
Paint and Body
11
Jan 23, 2008 07:24 AM
integra15
Apr 4, 2005 04:39 PM
Sassafrass
Jan 23, 2004 06:39 PM
neof69
May 7, 2003 09:12 PM
