after MPFI swap done engine doesn't warm up why?
ok after like a month im still wondering why my car doesnt have high idle when it warms up it has a low idle like the motor even shakes at idle in the morning and when i smash out and come to a stop it dies out so what could be the problem?
What did you swap on?
Thinking you may have done a Y8 intake manifold which doesn't have a sensor to bump up the idle when cold- just trying to make sure.
Maybe you just need to adjust the idle screw on the throttle body. No more than 2 and a half turns counterclockwise from the fully seated(clockwise) position . If the Throttle Position Sensor was moved during swap then maybe it is now out of adjustment. Just a few ideas good luck.
Iloveyourhonda92
Apr 11, 2015 07:46 PM
Leviatard
18
Oct 30, 2014 09:28 AM
mad21kid
Feb 18, 2008 12:52 PM
