car idles weird after highbeams on?
yeah, my jeep even does this, i just deal with it. not telling you to do the same, but i don't worry about it. if that thing doesn't make a new noise every day, thats when i get concerned.
Sounds like an alternator/charging system issue. Might want to remove both the alternator and battery and have them tested at an auto parts store.
if the idle is set incorrect or the timing is off this can happen. normally you either idle normal or up slightly with the lights on. if something is out of wack the iacv can wig & the idle will go all over. if you tap the gas and it normalizes i would check your idle setting, fuel pressure and timing. i've seen all 3 effect idle.
Zigory
Honda Civic (2001 - 2005)
Apr 13, 2018 06:30 PM
foonk
Nov 20, 2004 08:28 PM
