B16 swap in 90 dx running hot
Old Apr 26, 2009 | 10:12 PM
hatchet_honda's Avatar
Default B16 swap in 90 dx running hot
ive been driving my 90 dx hatch with a b16 swap. ive noticed the motor getting pretty damn hot. not overheating but def running hotter than my single cam si hatch. its got an aluminum rad with a slim fan that works fine and the temp guage never shows it getting to overheating temps (needle stays near the middle). the engine bay is a friggin oven tho, EVERYTHING is like almost to a melting state, my strut bar, the intake mani, wire looms, even near the headlights is hot as the friggin sun! its running fine and no coolant loss or nothin. do the dohc's just run a little hotter? im not real comfy with my engine sweatin like that lol
Old Apr 27, 2009 | 12:08 AM
Maverick's Avatar
Team Purple
Default Re: B16 swap in 90 dx running hot
if you think its running hotter than it should, i would check the coolant temp. sending unit to make sure youre getting the correct reading at the gauge....
Old Apr 27, 2009 | 04:24 AM
xaine's Avatar
get one of those infra red temp readers, point it at the engine and stuff and see what the real temp is
Old Apr 27, 2009 | 05:43 AM
jhammond_82's Avatar
Reject Papi
you could always change the thermostat, and temp sensor. mabye it is overheating and the sensor just doesn't work, or visa versa.
Old Apr 27, 2009 | 08:50 AM
its not smoking or anything..no power loss...runnin fine so thats why im stumped. i mean cooling fan kicks on at the right time and it doesnt heat up sooper fast or nothin. i just realized the engine bay is extremely hot! ill swap the temp sender and see if that changes anything. its the lil one on the head right? one wire pin..
Old Apr 27, 2009 | 09:20 AM
xaine's Avatar
i know on my b18 its the one on the thermo housing. two wire
dont know if yours is the same
Old Apr 27, 2009 | 10:08 PM
thats the cooling fan switch....
Old Apr 28, 2009 | 08:15 AM
xaine's Avatar
ok so i had it backwards
thermo housing is fan control
on head temp gauge
Old Apr 28, 2009 | 10:02 AM
i figured that was the one but wasnt sure... is till dont get why it would be working at all if it was bad. i mean it either reads temp or it doesnt...maybe its just me being used to my sohc si hatch running cooler...
Old Apr 28, 2009 | 10:37 AM
KaiPerrigo's Avatar
New User
my B18A1 doesn't run that hot , how is the airway to the radiator/fan? maybe relocate license plate off to side so more airflow to the engine bay, or a cheap cheap way is take off hood put some washers on the hood bolts and re attach hood makes the hood like a scoop so air flows in and up out onto windshield.
Old Apr 28, 2009 | 09:02 PM
airway is fine....i dont have a plate on the front bumper. how hot is your intake mani to the touch? and wheres your temp needle stay at on the b18? mines sorta in the middle. my sohc barely reads hot at all
Old Apr 28, 2009 | 09:23 PM
xaine's Avatar
i have b18 with new radiator and 180 deg thermostat
it runs under half way
thats with no fan!!!
normal car runs between 180 and 225 or so
shouldnt be any hotter that 225
most honda run 180-200
Old Apr 28, 2009 | 10:17 PM
my si hatch has a temp guage pod and stays under 190...and thats like 1/4 the way up on the stock temp guage. the b16 is more towards half way. i mean maybe im just comparing it to the sohc like i said before but is seems way too hot to me. i mean it runs fine just bugs me that its cooking under that hood
Old May 20, 2009 | 12:13 AM
ok so i changed my head gasket and when i filled the radiator all the coolant ran out of the motor!! it was everywhere! seeped between the head and block... i do believe this block is warped
b16a1eg6
Aug 7, 2008 09:54 AM
0bd1_Kanobe
14
Jun 4, 2004 04:09 PM
rob d
Jan 21, 2004 10:20 PM
NewYorkTypeR
Jun 15, 2001 09:09 PM
