A few Questions regarding Amp./ Speaker Specs.
Old Apr 26, 2009 | 09:03 PM
bopbop93030's Avatar
Default A few Questions regarding Amp./ Speaker Specs.
What is the diff. between having 4 Ohm and 2 Ohm in sound?
There is this Amp that has this spec.
50w rms x 4 @ 4 Ohm and 100w rms x 4 @ 2 Ohm
Also when they say 600w speaker, do you mean its 600w per speaker or 300w each?
Sorry for the noobie questions
Thanks
Old Apr 26, 2009 | 09:14 PM
98civdx's Avatar
Master Detailer
Default Re: A few Questions regarding Amp./ Speaker Specs.
the spec is just what it looks like, 50 watts to 4 speakers at 4 ohms, and the same but 100 watts to 4 at 2ohms. 2 ohm will always have more power.
it depends, what they could mean is 600 watts MAX between 2 speakers, or 600 watts MAX per speaker.
generaly you wont find a speaker with 600 watts Max or RMS, 300 MAX is more likely.
Old Apr 26, 2009 | 09:47 PM
So 2 Ohm has a better sound quality than 4 Ohm or does is not matter?
About the speaker its a 6x9 and has a 300w peak power handling, So does this mean its a 300w each or 150w?
Old Apr 27, 2009 | 06:05 AM
mrdeadman's Avatar
They let me pick
Not necessarily. It really depends on the listener, and the speaker itself.
Old Apr 27, 2009 | 06:06 AM
mrdeadman's Avatar
They let me pick
What is the RMS wattage spec of the speaker?
Old Apr 27, 2009 | 06:10 AM
imadigitalgod's Avatar
The reason that it will have "more power" is because 2 ohms puts less resistance on the amp than a 4 ohm speaker. "ohm" is a unit of resistance. Think of a water pipe: if the pipe has a bigger opening(less resistance) it will let more water (power) through
Old Apr 27, 2009 | 06:18 AM
fcm's Avatar
fcm
Old Fart
SQ will be better at 4 ohms then at 2 ohms, on some amps it makes on diff. in the amps output if it is connected to 4 ohms or 2 ohms, RMS output is the same.
When dealing with audio look only at speaker "continuous power handling", [also called RMS power/wattage] and amp RMS wattage, ignore anything else, [max power, peak power, total power and so on] speaker powers are for each speaker.94
Old Apr 27, 2009 | 07:18 AM
twentyhurtz's Avatar
x2, most sq guys run at 4ohm's, the less distortion and cleaner signal the better.. yea MAX power is a marketing gimmick,, notice how sony/pioneer have 760w max ratings and such, thats all Bull crap to get you to buy it, i hate when people tell me they have a 1000w sony amp when in all reality its more like 400w rms@2ohms@14.5v, and thats usually slightly overrated anyways, real world power is gonna be about 325w rms..
Thisboyjulio12
Audio / Security / Video
Mar 12, 2012 05:44 PM
musashiasano
11
May 18, 2009 02:58 PM
GetSmoked
Mar 11, 2005 03:20 PM
schwinn
Jun 19, 2002 10:54 PM
juniordc2
12
Jun 4, 2002 11:07 PM
