Suspension & Brakes Theory, alignment, spring rates....
EG coupe ex w/ rear disc?
Old Apr 26, 2009 | 07:19 PM
Maluko's Avatar
Default EG coupe ex w/ rear disc?
im a noob, do ex coupes(92-95) come with rear disc?
If they didnt, what parts would i need to do a swap?
thanks
Old Apr 30, 2009 | 06:14 AM
Lasky's Avatar
Default Re: EG coupe ex w/ rear disc?
some do some dont it depends on whether the car has ABS or not.. EX's with ABS = rear disc.. Ex's w/out ABS = no rear disc
Parts Required::
TRAILING ARMS - that have rear disc on them they can be off 92-95 civic hatch, coupe or sedan and you can also get them off any 94-01 integra
E-BRAKE CABLES - Civic sedan and coupe cables are the same length however integra and civic hatch cables are too short
BRAKE LINES - unless you can find a swap with the brake lines intact then your going to need to get some new rear brake lines
BRAKE FLUID - your going to need to bleed the brakes after completing the swap, make sure you have plenty of brake fluid for this swap especially if this is your first time bleeding brakes
And when you do the swap its usually a good idea to put some new rotors and brake pads on
hope this helps
P.S. check F.A.Q. sections before posting questions they have a lot of good information in there and can usually answer your questions
ke98248
Oct 21, 2008 09:49 PM
doubleshotz
Oct 12, 2007 03:46 PM
EJ1chevelle
13
Aug 17, 2007 10:52 PM
TeggerLS
Sep 19, 2006 06:43 PM
JSTOCK
Feb 25, 2002 08:13 AM
