rear disc brakes on 97 civic ex coupe -- parts to get for drum to disc swap?
I found out I needed to get the whole spindle and that I don't need to swap an entire trailing arm assembly to convert from my drum brakes to a 1999-2000 civic si rear disc brake setup.
I assume I need: Caliper, disc rotor, pads...
What else do I need from here: http://www.myhondapartsstore.c...ormal
Re: rear disc brakes on 97 civic ex coupe -- parts to get for drum to disc swap? (94EG8)
Anything else lol? I just don't wanna have it all then be missing ****. Hence why I asked
Seagull Management
Re: rear disc brakes on 97 civic ex coupe -- parts to get for drum to disc swap? (ke98248)
Rubber flex lines, i knew i forgot something. That should be everything This all assumes you're only doing the rear disc swap, if you are upgrade the front brakes then you will need a '99 - '00 Si master cylinder.
rubber flex lines? I have goodridge S.S. lines in the rear and front right now.. with brembo blanks and PBR/Axxis ultimate track pads in front.
