search sucks, mpfi questions
Old Apr 26, 2009 | 04:26 PM
sinepome's Avatar
Default search sucks, mpfi questions
i tried to search but just got tired of getting everything i didnt want.
i got a wire harness from a da teg b18.
and the injectors.
can i use these things for an mpfi swap?
if someone can point me in the right direction of where
i can find this info. thanks.
Old Apr 26, 2009 | 05:10 PM
89s1's Avatar
Default Re: search sucks, mpfi questions
if the injector clips are grey they are obd1 and you can't use a resisitor box, if they are a creamy white colour then do the mpfi as normal.
Old Apr 26, 2009 | 05:32 PM
sinepome's Avatar
thanks.
so even if there is a resister box on it its still obd1?
btw, theyare grey.
Old Apr 27, 2009 | 12:20 AM
89s1's Avatar
resistor box or not depends on what type of injectors you plan on running.
You need to be more patient and do a bit more reading.
Old Apr 27, 2009 | 08:53 AM
sinepome's Avatar
i know im not using the box, but there was one in the da so i just thought it was obd0. i guess i learned something new.
also whats the thing on the end of the fuel rail called?
the thing circled in red. thanks.
Old Apr 27, 2009 | 08:57 AM
jlicrx's Avatar
pulsation damper
Old Apr 27, 2009 | 08:58 AM
sinepome's Avatar
awesome! thanks for all the helps guys.
Old Apr 28, 2009 | 08:06 PM
sinepome's Avatar
anyone know where i can get one?
BRTBoostedLS
May 13, 2012 02:00 AM
91EF919
Oct 9, 2008 06:34 PM
racingant
Sep 28, 2005 05:10 PM
kur0ryu
Apr 26, 2004 05:05 PM
