redlining/rev-limiter early @6,500-6,7000rpms in my 88 rex with jdm gsr! help please
My car's running strong oils fine, no cel's
vtec is hitting but i'm redlining at about 6,500.
i searched and those had all ended up at dead-ends; Hoping this will be different!
-i'm running a 94 jdm gs
-i have enough of that bommb Royal Purle Oil in my motor!! haha
-i'm using my 0bd0 pr3 (jdm b16) ecu.. i'm going to get it re-maped to the gsr base map soon.
..So far what i got from searching, please verify,: check oil pan for dents ("not enough oil pressure") and check vtec solenoid screen
Thanks in advance peeps!!
vtec is hitting but i'm redlining at about 6,500.i searched and those had all ended up at dead-ends; Hoping this will be different!
anyone have this issue and got it resolved? any help would be appreciated. thanks
Even a auto ecu should be higher when I searched. It said a manual around 82-8300. Auto 7800 I think
yea its not auto.. i hope that its fixes itself once i get the gsr base map! i really have no idea. uggh!
does anyone else know of this problem happening to them or anyone they new and got it fixed?
Thanks everyone so far for the effort
try changing your plugs, wires and use high octane gas
I was using 87 and had the same problem with my b16. I changed my plugs, went to 93 and no more woes. Maybe a fuel filter too
what if you are throwing a code..... you should just take it to auto zone and let them check your codes for free. JUST to make sure if it really is throwing any codes. My type r engine had the same problem but i was throwing a code 6. it only let me rev to 65 like you untill i fix it and now at 89
which plugs are you talking about? i've alwayz used 91 octane with my b16 and now my gsr. but a 100 octane wont hurt haha. thanks for the advice!
I don't have any Codes/CEL's.. but if all else fails then i would just take me ecu in. thanks
CLICC916
Aug 12, 2002 05:24 PM
