My stock sleeve b20vtec build
Old Apr 26, 2009 | 07:10 AM
FSTVTEC's Avatar
Default My stock sleeve b20vtec build
My b20vtec stock sleeve build. all going in a hf crx
block
b20b
je pistons 12.1
eagle h beam rods
acl bearings
balancing
endyne lsv engine breather kit
head
b16 head
skunk2 springs and retainers
skunk2 stage 3 cams
skunk2 cam gears
race porting by local builder
jg victor x intake manifold
omni power 70mm throttle body
ge headgasket
logic motorsports 4-1 header
gate kevlar timing belt
r/c 370cc injectors
hondata gasket
b16 s1 cable tranny(jdm)
dynoed it yesterday and it went ok. went 215whp 148trq. i was expecting more but my tuner is afraid of going over 8500 because of the stock sleeves and i dont want the sleeves to crack. he was saying we could make more power if we kept going higher.
Old Apr 26, 2009 | 12:43 PM
Teamdiesel's Avatar
Default Re: My stock sleeve b20vtec build
I had the almost the exact same numbers with the Skunk2 stage 3 cams (208/148). I switched to the Skunk2 stage 2 cams outside the dyno and made 222/162 two hours later.
Old Apr 26, 2009 | 03:15 PM
FSTVTEC's Avatar
yea thats what i was thinkin. but i am also using a very restrictive exhaust(greddy sp2), so im going to go with a full 2.5in exhaust soon. but worse case senario I will switch back to s2s2 cams since I don't really want to go over 8500rpms because of stock sleeves.
Old Apr 26, 2009 | 08:02 PM
1.5Slowmatic's Avatar
why not just get a cutout and leave the sp2 for street driving? numbers do seem a tad low IMO. id try the cutout first than do the cam swap
Old Apr 27, 2009 | 04:43 AM
FSTVTEC's Avatar
yea my dad was just saying that last night. I'm ordering one next week. I know the numbers are low and we are trying to find out why. I think the tuner is wanting to play with the cam timing a little bit.
Old Apr 27, 2009 | 04:50 AM
mar778c's Avatar
Community Builder
Community Influencer
As far as your A/F, you could lean out a little from 7500 to 8500 rpm. Your graph says it's at 12.
What size exhaust are you running?
Old Apr 27, 2009 | 05:58 AM
hes running the SP2 which is 60mm, hence the cut out being ordered
Old Apr 27, 2009 | 06:07 AM
00MRSi's Avatar
I would go with 3inch exhaust piping. With a decent size resonator and Magnaflow oval or Vibrant 3.0 inch muffler it wont be very loud and will definitely help
Old Apr 27, 2009 | 06:47 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
vtec doesn't seem smooth at all man. did he not spend a lot of time smoothing out the maps?
Old Apr 27, 2009 | 02:32 PM
FSTVTEC's Avatar
I wish I could read dyno sheets man. thats why I posted this here so you guys can tell me what is wrong with this picture. lol. Honestly I wasn't there when the car was dyno tuned, my dad was. I wish I knew the first thing about tuning. I think the tuner knows what he is doing but this is my first time going to him and hes our local tuner.
Old Apr 28, 2009 | 05:57 AM
Teamdiesel's Avatar
your vtec is set at 5500 rpms, he should try 5000 rpms as there is to much torque spike at vtec. I noticed the same thing when I used my S2S3 cams. You also should have tried a different header.
Old Apr 28, 2009 | 06:20 AM
Teamdiesel's Avatar
here is one of the s2s2 vs s2s3 cam dynos I did that day.
Old Apr 28, 2009 | 07:48 AM
anyone else notice his torque and hp crossover at 7,500? that's wicked! i've never seen anything like that
R3Ycivic
40
Jan 15, 2013 02:01 PM
chickenbandit
Jan 25, 2012 07:38 AM
kryptonight
Sep 6, 2008 06:53 PM
Honda_Fanatic
23
Nov 9, 2007 07:54 AM
STHPERFORMANCE
20
Nov 1, 2003 07:09 AM
