How does this thing come off?
This is the lower ball joint. I need the WHOLE thing to come out of the knuckle so I can replace it. The bottom threads are BAD!
Here is a picture:
It is number [3] in that picture.
THANKS!
Here is a picture:
THANKS!
The lower ball joint has to be pressed out. You will need a machine press to do it. Any shop that can replace wheel bearings can usually press out the old ball joint and press in the new one.
[Modified by SLPR, 8:14 AM 8/16/2002]
remove the c clip - (on some models) and then rent a ball joint kit from Autozone or Trak Auto (in NVA area) - took me about 20 minutes each side.
if u dont have a ball joint puller u take a hammer and on the side of the arm u will see a lil bump smack it very hard a few times then try to bull the knuckle out or if u have a friend there have him pull on the knuckle while hammering
PatrickGSR94
Suspension & Brakes
18
May 12, 2010 09:55 AM
Dwight Schrute
Apr 20, 2007 03:42 PM
Flamenco-T
Aug 21, 2002 11:49 PM
