dash lights wont turn on..help
Old Apr 24, 2009 | 03:31 PM
b16 v8klr's Avatar
Default dash lights wont turn on..help
as the title says my dash lights and gauge cluster worked fine up until acouple days ago and now they wont turn on at all...any help is appreciated
Old Apr 24, 2009 | 05:24 PM
89s1's Avatar
Default Re: dash lights wont turn on..help
dimmer switch get turned down all the way?
Old Apr 24, 2009 | 06:16 PM
GLI's Avatar
GLI
bad connection...at the harness behind the cluster.
Old Apr 24, 2009 | 07:11 PM
b18cKoupe's Avatar
the one thing that all the dashlights have in common is the dimmer switch so I would start there. Same thing just happened on my 94 civic, all I did was follow the helms procedure and test for battery voltage on the middle wire with the key to acc(maybe diff wire on your car, not sure) and it had it then once I put the dimmer back in everything worked again. very weird, I assume something just came loose in the dimmer because the wiring connection was fine.
rickjames8
12
Jul 1, 2013 01:48 PM
MilanoEj1
Sep 27, 2010 09:52 PM
Figuroso08
Sep 10, 2010 08:21 PM
Antonio_P.R
Oct 21, 2008 09:52 AM
92'si
Nov 12, 2005 09:07 AM
