DASHBOARD LIGHTS HELP!!
IM NEW TO THIS FORUM AND I RECENTLY GOT A 1996 HONDA CIVIC LX SEDAN. I NEED HELP WITH THE DASHBOARD LIGHTS THEY DONT TURN ON WHEN I SWITCH THE LIGHTS ON AT NIGHT. SO ITS REALLY HARD TO SEE HOW FAST IM GOING AT NIGHT. WOULD REALLY APPRECIATE IT IF I GET HELP THANKS.
Re: DASHBOARD LIGHTS HELP!!
when you turn on the lights, smack the dashboard and see if they turn on if they do, you need to replace your dimmer switch.
I had the same problem with my hatch and that fixed it for me
Please turn off the all caps.
Have you checked whether 7.5A dash fuse 30 is blown?
Have you tried dialing the dimmer switch to brighten the cluster lights? If so, pry the dimmer switch out the dash, unplug the dimmer switch connector, and then use a jumper wire to short the red wire to the black wire in the connector. When you turn on the parking lights, do the cluster lights now come on?
Thanks redhatch00 tried it but it didnt work haha
RonJ@ht tried your method and it worked thanks alot!
Im alsdo having a problem on my power side mirrors my left one works fine but when i switch to move my right side it doesnt work any idea what it can be? thanks agian
Could be a bad switch, wire, or motor. Start by checking whether the right side motor gets battery voltage at the Grn/Wht or Yel/Blk wire when the adjustment button is pushed.
butafli593
09-29-2011 03:24 PM
