1997 Fully Built JDM Front Acura Integra 700+ HP
Time to move on to a new project car, this car has been garaged kept most of its life.
Price: Make an offer
For questions, pictures, and dyno charts please use the contact information below.
Contact Info:
decable@hotmail.com
Honda-tech IM
Body
1997 Acura Integra Sliver GS
80,000 Miles on the body
Clean Title
JDM Front End Conversion ( Black Housing)
Advan Custom Carbon Fibre Front Bumper
Advan Rear Bumper
VIS Carbon Fibre Hood
VIS Carbon Fibre Trunk
Lexan Rear Window
OEM Optional Integra Side Skirts
JDM Power Folding Mirrors
Powder Coated Radiator Support
Door handles converted to 4dr( no key holes)
Extra Set of Carbon Fibre Fenders
No Air Conditioning
Engine
1,000 miles on new block
Sleaved Aebs 2.0 liter block B20
9:1 CP pistons
Manley Turbo Tuff Rods
Eagle Race Crank
Z10 Oil Pan and External Oil Pump
Z10 Block Girdle
ARP Head and Bottom End studs
ATI Race Crank Pulley
Maziere Water Pump
GSR Head Fully Ported
Manley Valves
Ferrera Valvesprings and retainers
CTR Camshafts
Cam Gears
Victor X Intake Manifold
70mm V-band Throttle Body
Race Radiator
Suspension
Z10 Traction Bar
Skunk2 Coilovers with Koni Yellows
Skunk2 Camber Kit
Full Chassis Bushing Kit
Brembo Rotors
Stainless steel brake lines
Interior
Memory Fab Carbon Fibre Bucket Seats with Harnesses
10 Point Certified Roll Cage
Type R Center Console
Type R Cluster
Carbon Fibre Roof Lining
Sparco Steering Wheel
New Carpet
Electronics
Innovative Boost Controller
F.A.S.T ECU with Wideband
MSD Digital 7 with MSD II Coil
Viper Alarm with pager
MB Quarts Speakers
Boost Gauge
EGT Gauge
Oil PSI Gauge
Water Temp Gauge
Fuel PSI Gauge
Optima Battery relocated to trunk
Drivetrain
Clutchmaster Multi disc Clutch
Aluminum Flywheel
DSS Stage 5 Axles with upgraded Hubs
Arp Extended Wheel studs
Place Racing Motor Mounts
B16 Transmission with ceramic ball bearings
Quafe LSD
Ceramic Wheel Bearings
Converted to Non-ABS brake Setup
Fuel
Stainless Steel Fuel Lines
-10 Feed
-10 Return
AEM Fuel Rail
Aeromotive Fuel Regulator
External Aeromotive Eliminator Fuel Pump
Sumped Tank
2 Filters
1000 Cc Precision Fuel injectors
Turbo System
900 Hp Double Back Door Intercooler
Custom Stainless Steel Double Slip Collector manifold
Garret GT4088R with ceramic ball bearings upgrade
Stainless Steel Oil Lines
Full 3 inch Exhaust
Full 3 inch race exhaust
Contact Info:
decable@hotmail.com
Honda-tech IM
Body
Clean Title
Advan Rear Bumper
Lexan Rear Window
No Air Conditioning
Engine
9:1 CP pistons
Eagle Race Crank
Z10 Block Girdle
Maziere Water Pump
Manley Valves
CTR Camshafts
Cam Gears
Race Radiator
Suspension
Z10 Traction Bar
Skunk2 Camber Kit
Brembo Rotors
Interior
Type R Cluster
New Carpet
Electronics
MB Quarts Speakers
Boost Gauge
EGT Gauge
Oil PSI Gauge
Water Temp Gauge
Fuel PSI Gauge
Drivetrain
Aluminum Flywheel
Quafe LSD
Fuel
-10 Feed
-10 Return
AEM Fuel Rail
Sumped Tank
2 Filters
Turbo System
Full 3 inch Exhaust
toobuzy4suicide
Jun 26, 2014 03:01 AM
LS VTEC Engine F/S, B18C5 Block F/S, GSR HEAD F/S, CRX Carbon Fiber, Full Ferrea Vtec Eliminator Val
Spec...G@rage
Jun 14, 2006 03:50 PM
