Piston to deck height with LS crank/rods in a GSR block-
Old Apr 24, 2009 | 07:02 AM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Default Piston to deck height with LS crank/rods in a GSR block-
I know that the LS and GSR blocks are nearly identical in height, but have heard there is a slight difference- From my research I gain that the piston to deck height would be .022
With a stock GSR or LS it is at .03 correct?
So using C speeds calculator, I would have 9.9 compression using:
81mm bore
89mm stroke
GSR head
LS pistons
and .022 piston to deck height-
Am I doing my calculations correct? Is the piston to deck height .022?
Thanks!
Old Apr 24, 2009 | 07:52 AM
EK9 CTR's Avatar
Default Re: Piston to deck height with LS crank/rods in a GSR block-
It should be 0.035 with LS pistons... The GSR/Type R blocks are taller... Hence the greater piston to deck clearance....
Old Apr 24, 2009 | 08:38 AM
nytosc's Avatar
Thanks! good info- anyone confirm this?
3k9civic
Feb 14, 2006 03:35 PM
slambedcivic
Jul 14, 2005 05:05 AM
saleensolution
Mar 23, 2005 11:17 AM
NightmareApex
22
Dec 18, 2004 10:53 PM
96tegsr
Jan 24, 2002 06:41 AM
