C-clip for Speedo cable?
Old Apr 24, 2009 | 05:53 AM
Charlie Moua's Avatar
Default C-clip for Speedo cable?
I lost mine or it fell out when my stock speedo cable broke for having nearly 246K on it.
So I bought a new OEM DA one.... (seems thicker and slightly longer)
I'm running a gsr hydro tranny.
I tried to but it in and it would not stay...
q?
1) does it need the c-clip?... if not what am i doing wrong
2) if the c-clip is required, where can I buy one?
TIA,
Charlie Moua
Old Apr 24, 2009 | 06:28 AM
4drEF's Avatar
Keyboard Humorist
Default Re: C-clip for Speedo cable?
In a pinch, a small paperclip that fits through the groove or some bare wire.
(I need to buy a new one too! No idea where from though -sorry)
It does need a clip to really hold it in there - some people say they have been running for years without it, but mine is a loose fit and won't stay in at all without something.
Old Apr 24, 2009 | 06:59 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
My 90CRXHF runs without one... I do get a little speedo bounce when cold out... and I have lubed my cables twice in 4 months to keep the squeaking down...
Old Apr 24, 2009 | 08:34 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Here are some pics from another thread:
At the transmission,pull the inside completely out of the housing:
The entire inner cable should be 34 3/4" long..
If not,it is broken..
If the cable is in one piece,Grease it up and stick it back in the housing:
The green line should be inserted all the way to where the slot is:
It is then held in place with the clip which is usually found inside the rubber cover:
You may have to turn the cable until it lines up with the drive in the sensor...
Old Apr 24, 2009 | 09:48 AM
You the man.
This should be in a the FAQ Thread
Old Apr 24, 2009 | 10:03 AM
hatcht9x's Avatar
of course honda sells it
Old Apr 24, 2009 | 11:54 AM
rustbucketrex's Avatar
Honda Part # 90637-689-000 (Clip, Speedometer Cable). $2.03 at Honda Parts Unlimited
Old Jun 24, 2009 | 03:47 AM
wesley4556's Avatar
New User
so thats why i cant pull my speedo cable out.
turbo-crx
Oct 24, 2008 06:44 PM
JLefevers
Apr 8, 2006 06:21 PM
CHRIS 1.8
12
Feb 7, 2003 02:04 PM
Snail Tuning
Jan 17, 2003 04:53 AM
crx(gator)
Sep 28, 2002 08:10 PM
