FS/PA:High comp lsvtec longblock
Head:
94 Jdm b16 head
revhard dual springs and titanium retainers
new oem valves and valve seals
Skunk2 Stage3 cams All motor tuner series
Type-R Intake manni portmatched to a 68mmtb
68mm power tb
Golden Eagle fuel rail
Precision 440cc injectors
Type-R valve cover
Block:
Ls block with P-30 pistons je proseal piston rings reconditioned ls rods w/ arp rod bolts
2 layer Head gasket
New Type-R oil pump
New Type-R water pump
New Gsr timing belt
Golden Eagle Lsv conversion kit
Type-R Flywheel w/ arp flywheel bolts
Oem hydro clutch w/arp pressure plate bolts only 1500miles on clutch
Will include phearible chip to run the 440cc injectors made 196whp with this chip without tuning
The motor is in my car right now runs great i replaced every seal and gasket in this motor no leaks and definitely does not burn oil, engine runs on full synthetic oil, have dyno sheets and video
it only has 6k on it since the build and i have many receits for the parts and machine shop, compression test was done 270psi on every cylinder looking to get 2500 obo will through in tri-y headers for 300 more no trades
DYNO VIDEO:
http://s187.photobucket.com/albums/x...urrent=004.flv
Head:
94 Jdm b16 head
68mm power tb
Type-R valve cover
Block:
2 layer Head gasket
New Type-R oil pump
New Gsr timing belt
DYNO VIDEO:
Nickb257
Sep 4, 2011 08:18 AM
Nickb257
Northeast (Sales)
Aug 23, 2011 04:18 AM
Nickb257
Aug 23, 2011 04:15 AM
